Home > Technical (L322) > Steering wheel stuck at maximum height.
Smiggy
United Kingdom 2007 Range Rover Vogue TDV8 Zambezi Silver
My steering wheel has got Jammed up as high as it can go.
I can hear the motor turning but nothing happens.
It still moves in and out ok.
Has anyone else had this issue and how did the resolve it?
Thanks
Post #539350 4th Jan 2020 8:49am
rjff
There are some threads on the column adjustment about on here. Have a search, but you may find it has to do with the motor/gearing things on the column. IIRC not easy or cheap.
https://www.fullfatrr.com/forum/search.php...rch_time=0
https://www.fullfatrr.com/forum/topic51532...ing+column
https://www.fullfatrr.com/forum/topic48295...ing+column Cheers
Richard
Gap IIDBT
Post #539379 4th Jan 2020 4:38pm
Equinox
England 2007 Range Rover Vogue 4.2 SC V8 Zermatt Silver
Re: Steering wheel stuck at maximum height.
Unnecessary quote removed
Hi just had this on an l322 tdv8 vogue, with the steering wheel housing panel removed (3 screws) you can access the winding motor, 2 screws down it drops - from there you can use a 10mm spanner to wind down the wheel to a set position,
I took the motor out for 3 weeks and there was no adverse effect to the car whilst driving. the repair - which lasted on ly 3 weeks was to dremel open the motor housing - inside is a 10p coin sized plastic gear wheel that slips on the centre spindle - there is a fix somewhere on line to weld in a pin to stop it spinning - I chem welded mine back on but as I say it lasted 3 weeks now just sits in the centre position - the alternative is a new gear/motor at £100 or so on ebay but for a 50p gear from RS Im way to tight to spend that amount. its no to be confused with the in/out common fault though - totally different but easy to confuse for an idiot like me. hope that helps
Post #539401 4th Jan 2020 7:56pm
Smiggy
Thanks for the help.
I will pop the covers off and have a look tomorrow.
Hopefully I can sort it. It's the only thing wrong with the car at the minute so would be nice to get it sorted before the next big job comes along.
Post #539402 4th Jan 2020 8:07pm
Equinox
Im only here looking cos the next big problem came very soon after that - but at least its a learning curve never owned a RR before and (TBH) they scare the cr'p out of me with al the things commonly going wrong . Smile
Post #539409 4th Jan 2020 8:21pm
