Home > Technical (L322) > L322 Vogue 2011 Brake discs size? |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7635 |
4th Jan 2020 8:15pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3195 |
Regarding the judder, possibly caused by sticking caliper slide pin. Easily checked by a short run and then testing to see if one wheel is hotter than the others. John
4th Jan 2020 8:16pm |
Fatzo Member Since: 11 Nov 2016 Location: Rigny Posts: 82 |
Thanks for your answers guys!
4th Jan 2020 9:20pm |
Thinking about it, since the brake judder appeared after changing front discs and all pads (front and rear), I think the problem could be limited to the front wheels only.
4th Jan 2020 9:24pm |
Generally, if you feel the judder through the steering wheel it tends to be the fronts. Through your seat, it’s the rears.
4th Jan 2020 11:08pm |
umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433 |
New discs may be faulty?
5th Jan 2020 5:41pm |
Yes I think they re faulty
5th Jan 2020 6:38pm |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 897 |
45 piston rear caliper? They must be bloody small pistons! Mike |
6th Jan 2020 11:01am |
yeah I know, and that’s from the PDF brochure.....
6th Jan 2020 5:34pm |
I believe that should read 45mm single piston....
6th Jan 2020 9:40pm |
Well some news.
6th Jan 2020 11:25pm |
The extract I posted above is from the Range Rover brochure....
6th Jan 2020 11:58pm |
7th Jan 2020 9:05am |
Ah, sorry for the confusion, in trying to find a pdf of the brochure for you to link to, I had to search the web, and the link is for the 3.6 TDV8.
7th Jan 2020 10:02am |
