Home > Technical (L322) > Thermostat install gone wrong
horse86
United States 2014 Range Rover Autobiography 5.0 SC V8 Causeway Grey
2008 Range Rover HSE....so i watched the vid &fbclid=IwAR0MCdBjMxYrg6R-McNNdycOWoMxHzuaabbE1PejSC4m4SDDNdiQ17ni2qA
and i took it all apart. Went to put the new thermostat in and the guy said to make sure the pin moves back and forth in the new thermostat so I pulled on it and it came out. I pushed it back in and I guess it didn't seat fully back in and when I went to line up the pin and put the new thermostat into the housing the pin came out and fell into the housing/hose. Who knows where it is now or how far down the hose it went. Having a oh sh**** moment here. Am I screwed? I'm not sure where that hose leads to...it goes downward...but its too dark to really tell if it goes to the rad
Wondering what the probability of me getting/finding that pin. Can the the car be driven with that piece somewhere in the system if I buy and put in a new thermostat or will that piece in the system cause catastrophic failure 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #539680 7th Jan 2020 12:21am
kevinp
Can you securely tie a small magnet to some string and drop it down the hose?
Post #539685 7th Jan 2020 4:05am
horse86
I have a magnet stick but it wouldn’t go past the “tube” in the housing that the pin inserts into...not enough room. I also checked and the pin on the stock thermostat isn’t steel so the magnet wouldn’t work.
I’m not sure if that side of the hose/thermostat dumps right into the Rad and my chances of getting it out or consequences of it in there. 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #539687 7th Jan 2020 4:53am
