![]() | Home > Technical (L322) > 4.2 SC - Copious amount of steam on start-up |
| V8Noise Member Since: 25 Apr 2015 Location: Dereham Posts: 424
Get a sniffer test done. Cheap and easy at your local garage. It'll point to exhaust gases in the coolant, ergo, possible head gasket problems. 2017 5.0 Autobiography Supercharged
| Mulcher Member Since: 08 Aug 2016 Location: Shropshire Posts: 240
Where is the steam coming from? 2006MY 4.2 SC
| Glibbs Member Since: 18 Aug 2019 Location: West Somerset Posts: 114
From the exhaust. Range Rover 4.2 SC
| Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2287
It might be worth taking the plugs out and having a look to see if any are steam cleaned or rusty |
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3989
If you are loosing coolant and steam is coming out of the exhaust on start up it's likely you have a head gasket problem.
| MattHughes86 Member Since: 01 Jun 2019 Location: Gloucestershire Posts: 140
We had similar problem at first, which then led to an over heat problem.
Many thanks. Range Rover 4.2 SC
| kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 335
@matthughes86 what's access like for what you are doing? I've always thought if I have to go that deep I would take the whole engine out. |
Kezbo,
| All times are GMT |
