![]() | Home > Technical (L405) > Wheel Alignment - what type? |
| roberlar Member Since: 16 Feb 2019 Location: Buckinghamshire Posts: 203
When I bought my AB from an independent I noticed it pulled very slightly left so they fitted new lower suspension arms on the front and new anti roll bar bushes. They then had a four wheel alignment carried out which showed green all round within tolerances. A few months later, I had new tyres fitted all round as the fronts were worn on the inside and rears were getting a bit thin. I decided to have a Hunter alignment carried out and despite no kerbing or similar, some of the readings were a fair way out. The operative did improve things, but said he couldn't get all adjustments within tolerance. That said, the car handles ok and I can't see any uneven wear on the new tyres. So in my case, was the first alignment really correct, and did the operative of the second alignment have the knowledge to adjust properly within tolerance ? In summary, I'd make sure it's done by someone who's familiar with the 405. |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874
what makes you think you need an alignment Ryan? ... - .- -.
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352
Tight Tolerance Mode needed |
| charlie croker mk2 Member Since: 21 Jun 2017 Location: Yorkshire Posts: 174
Might be a considerable drive for you but if anyone needs alignment in Yorkshire ? this guy is fantastic .
| Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16403
All MD's have to have a Hunter alignment machine as of 2016 ish...
Craig : I didn't know that , I have not been back to a MD for a few years ! |
| pld118 Member Since: 25 Mar 2013 Location: Bairns Posts: 4218
The very outer edges of the front tyres have slight shoulder wear Stan... And the steering wheel is very slightly off centre. Farnell LR charge £120 incl vat for 4 wheel alignment and a local LR specialist charges £95 for it... |
circa £100 seems the going rate for a hunters....imperial tyres here in swindon charged me that on my SC.. ... - .- -.
| Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1883
Tight tolerance mode
Wot Mikey said |
| nwmgc Member Since: 27 Jan 2014 Location: London Posts: 159
I was obliged to get two new tyres this weekend at KwikFit and they - I thought - kindly suggested a free check on the Hunter machine, saying they would charge only if an adjustment was needed at a standard price of £79.95 inc. VAT.
good price that |
| ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1672
bit of a 'holy thread resurrection Batman' but thought I would just share my experience today with Kwik Fit
| Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1442
Any idea Which selected branches? 2018 SE SDV8 4.4 Byron Blue |
