![]() | Home > Technical (L322) > Limp Mode - Manifold pressure |
leusfx Member Since: 24 Jul 2018 Location: prague Posts: 25 ![]() |
Thanks gilesharrison and cass for information.
gilesharrison Member Since: 04 Aug 2018 Location: Cumbria Posts: 163 ![]() ![]() ![]() |
Wow. Good luck. I don't know anything about plastic welding but you definitely do.
Thanks.
Good effort. I hope it lasts well. |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 782 ![]() ![]() |
I wish I’d thought of that - the welder costs less than a new manifold never mind the labour involved.
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2947 ![]() ![]() ![]() |
This is the exact same fault I've got. I've sprayed soapy water on the manifolds but I don't see any bubbling.
Swap the MAP sensors over and see if the fault remains on the same side on the engine. |
I’ve done that. Also replaced the top hoses with silicone even though there were no splits 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
When I had my manifold crack, the error regularly used to happen up one certain hill. However, other times it seemed temperature dependant. Like when it was cold, it was less likely to give the error. Hot weather, or when the engine was hot, seemed to happen more.
What is your trouble code when Limp mode happens?
Yes that’s the fault code.
Rule out faulty turbo actuator with your IIDtool.
How do I increase by 5% whilst driving? Once it’s data logging it can’t be changed can it? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
That's supposed to be done when idling. |
