Home > In Car Electronics (L322) > lights |
Harlin Member Since: 06 Jul 2016 Location: ,essex Posts: 157 |
36 people and nobody has gone outside to have a look |
8th Jan 2020 11:10pm |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 |
Dont think so , why would they 2015 4.4 AB
8th Jan 2020 11:36pm |
why would they go outside or stay on |
9th Jan 2020 12:04am |
Why would they stay on , ny 2007 one didnt 2015 4.4 AB
9th Jan 2020 12:08am |
i am having a problem with battery drain was just asking because i have not noticed them on before |
9th Jan 2020 12:12am |
The lights staying on would definitely not help. 2015 4.4 AB
9th Jan 2020 12:13am |
just got to work out how to turn them off then |
9th Jan 2020 12:15am |
Hopefully one of the experts on here will help 2015 4.4 AB
9th Jan 2020 12:19am |
thats what i was hoping for |
9th Jan 2020 12:22am |
ctjfb Member Since: 20 Jun 2019 Location: Northampton Posts: 32 |
I seem to recall from several other threads on voltage drain that these lights going out (eventually) is one of the things to check when seeing if the various ECUs are going into sleep mode correctly ...
9th Jan 2020 2:29am |
maric995 Member Since: 04 Apr 2019 Location: zagreb Posts: 58 |
The background lights on the shifter must turn off after about 20min when the car goes to sleep mode regardless if it is locked or unlocked. RR HSE 4.4 2006 LPG |
9th Jan 2020 7:34am |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3649 |
I’m doing this from memory as I now have a 405 but the Park light was not on all the time on my previous cars. I would have noticed it while driving- particularly at night. I don’t know about parked I just locked and walked away.😀 Geoff |
9th Jan 2020 9:26am |
RJH Member Since: 22 Mar 2015 Location: Coventy Posts: 396 |
Other than the red flashing LED on the dash I'd have thought there should be no lights on in the car once its locked & shut down after 20 minutes or so.
9th Jan 2020 10:26am |
Brian Considine Member Since: 15 Apr 2019 Location: Garlinge Posts: 428 |
Patience is a virtue (& something you need when running a FFRR) They do stay on for a while & then go off as part of the "go to sleep" process. 2003 Range Rover Vogue TD6 |
9th Jan 2020 10:40am |
