Home > Technical (L322) > iPhone integration
MrP
England 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
iPhone integration
In the middle of installing a BT module and connecting up my iPhone. Used navcoder for get BT unit to pair and that bit all works nicely as do all the steering wheel buttons etc. Problem I've hit is the mic. The overhead mic has three wires yellow, thin black and thicker black. I need to trace them back to the rear of the car (using bits of old loom to save ripping the car apart) but am having no luck. Anyone done this already and know where I can pick up these three wires? Its the last bit to do and sods law has just kicked in. "On first name terms with my local Dealer......now."
'61 Plate 5.0SC Autobiography - in Black ——— Gone
'53 plate 4.4V8 Vogue Bonatti Grey inside and out. ----- Gone
Post #45153 8th Jan 2011 3:01pm
SteveMFr
Site Sponsor
The wires basically run from the mike to the ULF. If you have the voice control module they do make a quick stop there first.
Can you not find the connector overhead or what is the exact problem? I assume you re-pinned the big 54-pin connector at the ULF? IIRC the mike pins are 1, 19, and 21 in the 54 pin connector.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #45155 8th Jan 2011 3:21pm
MrP
I have a re-pinned loom (54pin plug and big white plug) from Adam at l322.com into the bmw ulf. All the phone functions for the ulf are working and integrating with the car (buttons etc). The only bit of the re-pinned loom I have yet to connect up is the mic. I tried tracing the wires back to the original 54pin plug but none of the colours seemed to match up...
If the wires go to the voice module first I will have another look as so far I have been looking for them at the old 54pin plug end of the loom. I'm intending to tap into the existing loom rather than run the new one through the car hopefully saving me some hassle. "On first name terms with my local Dealer......now."
Post #45157 8th Jan 2011 3:43pm
MrP
@SteveMFr - I seem to recall you mentioned the pinout from l322.com had a mistake somewhere - I'm getting a couple of strange things with the BT iphone integration (doesn't hang up the call from the RR only the phone, causes the central screen to reboot occasionally etc.) and am wondering if this is the cause. Do you remember what the pinout mistake was? "On first name terms with my local Dealer......now."
Post #53859 10th Mar 2011 9:33am
SteveMFr
Site Sponsor
I've looked and I can't find my notes... But I believe the probs were related to cradle/mic (IIRC, amongst other things, the correction on L322.com where the mic wires are switched is incorrect).
The hang up prob you describe sounds more like a general BT prob, tho. What gen is your ULF again (or did you mention it)?
The screen re-boot would worry me. What does that look like?
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #53932 10th Mar 2011 5:52pm
MrP
Its a Gen13 ULF
the reboot has happened before when not using the BT - the Nav disc got a bit confused (its a Mk4)
I dont have the cradle connected fully yet and do the pairing via navcoder and iBus as I never got round to sorting out a pairing button. "On first name terms with my local Dealer......now."
Post #53934 10th Mar 2011 5:59pm
daveo
mr p, did you remove all the wires that were not in use in the 54 pin plug, this caused me a few probs as i didnt..
what i phone are you using V8 facelift Range Rover Autobiography 22" wheels.
Post #53958 10th Mar 2011 7:46pm
MrP
No i didnt. Adam at l322.com sent me a new loom that was re-pinned for the 54 pin plug so i just used that. I'm using an iphone4
do you have a doc showing the pin outs I need? (and the ones I dont) "On first name terms with my local Dealer......now."
Post #53972 10th Mar 2011 8:35pm
daveo
i repined my plug following the diag from his site, i only had to swap the mic wires around at the 54 pin plug and all worked. have you tried pairing a different pone V8 facelift Range Rover Autobiography 22" wheels.
Post #53982 10th Mar 2011 9:03pm
Ajay(UK)
United Kingdom 2015 Range Rover Autobiography SDV8 Indus Silver
iPHone 4 and Gen 13 ULF should work fine, never had a problem with mine. Thumbs Up As for a pairing button its just two wires that need a momentry contact switch so you could wire up a door bell button if you wish Laughing Certainly a very long winded way hooking up Navcoder Confused
I will try and dig out my own "home made" pinout wiring chart if it helps?
Andy. 22MY Defender 110 D250 HSE X Dynamic, Gondwana Stone.
SWMBO: 2022 RRS D300 Autobiography, Firenze Red.
Gone:2015 L405 SDV8 Autobiography, Indus Silver with Black Pack.
Gone: 2014 Discovery 4 HSE Luxury Firenze Red
Gone: 2006MY Java Black TD6 Autobiography
Gone: 2013 Jaguar XKR Convertible, Italian Racing Red with Ivory Seats
Gone: 2010MY Stornoway Grey TDV8 Vogue SE with RSE
Gone: 2008 Disco 3 HSE, Hybrid Tv + Retro-fit RSE System & DVD
Post #53992 10th Mar 2011 9:39pm
daveo
hi, i thought he was having probs with the mic V8 facelift Range Rover Autobiography 22" wheels.
Post #54000 10th Mar 2011 9:56pm
MrP
AJAY - the pinouts for the pairing button would be a great help so yes please.
The Mic is all working find - dialling, speech, sound, answering all work great - hanging up doesn't which is very strange.
Not tried a different phone but have some so will do.
Pairing button would make this a lot easier Smile "On first name terms with my local Dealer......now."
Post #54016 10th Mar 2011 11:23pm
Ajay(UK)
Oh! Its been a while since I last looked at my pinning chart and notes, time to get my head around the wiring again Embarassed
To help me - Do you intend fitting a pairing button in the rear by the ULF or up front under the centre arm rest?
Post #54103 11th Mar 2011 3:53pm
MrP
I can do either - I have the loom connected up to the centre arm rest even though I am at the moment not using that bit.
Much appreciate the help Thumbs Up "On first name terms with my local Dealer......now."
Post #54104 11th Mar 2011 3:58pm
Ajay(UK)
Ok well up front there are only four wires used in the 18 pin connector and should be as follows:
Pin 1 - Red - Supply Voltage
Pin 2 - Brown - Ground
Pin 6 - Green -
Pin 14 - White -Pairing
Now because I changed the RR phone cradle to the BMW Eject Box which has the built in pairing button mine worked fine without further investigation. From what I can remember it is the white wire (pin 14) thats the one that needs to be used for pairing either by "touching" with pin 6 or Pin 2. I would suggest testing with pin 6 first.
Turn off your ignition and bridge Pins 14 & 6 temporarily, then turn on ignition to position 1, count to 3 and disconnect your bridging wire - If the monitor displays "Bluetooth Pairing" you're sorted, if not then it has to be pin 14 and 2 Wink You just repeat the process, DEFINATELY NOT PIN 1 Shocked
Post #54111 11th Mar 2011 4:30pm
