Home > In Car Electronics (L322) > L322 Questions |
Hi and welcome,
11th Jan 2020 9:27am |
TDSIX Member Since: 19 Feb 2017 Location: Stirlingshire Posts: 210 |
I believe there is an apple car play option called navtool, its from the USA and costs around $500, it's a moderately easy install and gives touchscreen access to your phone with apple car play or android... more info in the ice forum. 2010 FF 4.4 TDV8 Vogue - Gone
11th Jan 2020 7:09pm |
https://www.fullfatrr.com/forum/topic53128.html 2010 FF 4.4 TDV8 Vogue - Gone
11th Jan 2020 7:23pm |
the_ferret82 Member Since: 10 Jan 2020 Location: Hertfordshire Posts: 50 |
Hi northernmonkeyjones,
11th Jan 2020 10:33pm |
Thank you, this makes good reading and seams like a nice bit of kit
11th Jan 2020 10:34pm |
I hadn’t seen the nav tool post. That’s an inteeedting bit of kit. There is nothing that can't be fixed with a hammer😜😜
12th Jan 2020 9:54am |
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 508 |
I have a 3.6 with ipod integration and I find it very limited in functionality. In terms of head unit control you can only select from 5 playlists or skip forward / back. There is no way to play songs outside of the playlists you've created other than by going through every single track (of which I have thousands).
12th Jan 2020 10:00am |
And just to clarify one point, the official kit doesn't actually replace the CD changer. It gives you the option of using either. You have to decide which you want before you start the car though and you cannot change without a restart.
12th Jan 2020 11:11am |
I think the part number is VPLME0004 if I haven't put you off the idea altogether... 2016 Skoda Octavia VRS Estate
12th Jan 2020 11:22am |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3194 |
That is the correct part number. I fitted it to my 3'6 a couple of years ago. It requiress stripping out the glove box to install. It was fine for playing music from an ipod and better than just the cassette player. It has USB connection as well as the 30 pin apple connection. I didn't have problem with random as I put both the car cd on random and the ipod on shuffle. It does have limitations though.
12th Jan 2020 12:07pm |
hi Mike, thank for the info. if im honest i dont think these limitations would bother me what i really want is a USB socket so i can plug a flash drive in and plag songs form there. the Ipod would be good so i could try one of these Ipod to bluetooth adaptors that exist i have found then successful in the past in my other cars |
12th Jan 2020 5:49pm |
I'm not sure what control you get over playback from a USB stick. If you're happy to play songs in order or skip the odd song I'm sure it would work fine. 2016 Skoda Octavia VRS Estate
12th Jan 2020 8:49pm |
Hi Mike,
13th Jan 2020 10:11am |
Your question prompted me to try it out and I've realised that I really gain very little from having an iPod connected over just attaching a USB device. That said, what you get is access from the touchscreen to the first five top-level folders on the device (CD1-CD5) and an "all tracks" playlist in the form of CD6. You can then skip back and forth within these.
13th Jan 2020 10:54am |
