Home > Technical (L322) > Fuses
rvbush
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
Fuses
Relating to the 2010-12 L322 4.4 TdV8. Does anyone know if the fuse marked 'spare' at No' 16 in the glovebox fusebox is a switched ignition live? Asking as I want to fit a piggy back fuse to power a dash cam. Thanks in advance.
I've looked at the wiki re fitting dash cams, but that seems to relate to the earlier vehicles fitted with standard blade fuses and the later ones have mini blades and a different layout. Drives:
2010 FFRR TdV8 Vogue - Stornoway Grey
2010 FFRR TdV8 Vogue SE - Zermatt Silver
1998 BMW E36 M3 GTII
Post #539741 7th Jan 2020 5:24pm
rvbush
Anyone, pleeeease? Drives:
Post #540149 11th Jan 2020 10:15am
GraemeS
Australia
The wiring schematic shows the fuse is ignition switched and supplies the engine bay auxiliary fuse panel where it powers the relay for the heated washer jets.
Post #540242 11th Jan 2020 8:42pm
rvbush
Brilliant GraemeS, thanks. I'm hopeless at reading wiring schematics. This looks like an ideal place to piggy back. Drives:
Post #540281 12th Jan 2020 9:13am
rvbush
Just to complete this, at long last I got around to hard wiring the dashcam, used fuse 16 to piggyback from and all works fine. Drives:
Post #545642 1st Mar 2020 9:47am
