Run a live feed direct from the battery to the unit with a 20a self resetting fuse in line
Run a thickish 2 core cable from the unit to rear of the car. Use one of the cores as the trigger from the brake light and the other for the actual braking signal to the trailer.
I use Tekonsha brake controllers, mine is located just above the OBD port on the dash. Easy.
Your UK trailer plug will need to be rewired as its not the same over here. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
