Home > Maintenance & Mods (L322) > Facelift advice
Matthew
United Kingdom 2004 Range Rover Vogue Td6 Java Black
Facelift advice
Hi all I have a 54plate Td6 and after some advice on doing the facelift conversion to the 2006 style on the headlight wiring not shure if this has been asked/discussed before if it has I do apologies in advance [/i]
Post #540517 13th Jan 2020 11:56pm
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
What do you need to know?
It's all fairly straight forward - buy yourself some of the plugs for the new headlights, cut off the old plugs and wire the new ones in their place.
There are some pics on the internet about which wire goes where. I found that this one the best, though there all seem a bit wrong. One issue that no-one seemed to discuss was how to wire in the shutters for the Xenon main-beam. My shutters didn't work at first so the lights dazzled oncoming drivers when on dip. Wiring the shutter actuator into the power for the main-beam solved it.
 Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #540974 18th Jan 2020 11:24am
Matthew
Thanks for the reply it was the wiring side I was stumped on as like you said about the shutter I have the plugs and about a foot of wiring there with the lights with that diagram it should help only other thing aswell I wanted to know about wash the washer jets on the face lift bumper is there anything extra I need to get to get them working properly cheers
Post #541005 18th Jan 2020 7:06pm
Zebedee
I never got the headlight washers to work properly - though I think it is a requirement for an MOT - and never got around to solving it.
I bought a mini high pressure headlight washer pump, which fitted in place of the old RR pump - though I could never work out what was required to get it to squirt. Mind you, I never tried very hard and really should take the headlight out and give it another go.
If you solve it, post the answer here. Current:
Sold:
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
Post #541065 19th Jan 2020 4:16pm
