![]() | Home > General > 05 RR NA with the Jag engine |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7965 ![]() ![]() ![]() |
I’ve had neither, but I seem to remember that the general consensus on here is that the Jag 4.4 is a “better” engine than the BMW unit.... not sure if it’s smoother or a bit more modern....
maric995 Member Since: 04 Apr 2019 Location: zagreb Posts: 58 ![]() ![]() ![]() |
I am owner of a late 2005 l322 with the jag 4.4 engine with currently 150.000 miles. I have it for a year now, and the engine is smooth and reliable. The first owner who had it, installed LPG and the car runs on it for the last 20.000 miles.
nwmgc Member Since: 27 Jan 2014 Location: London Posts: 159 ![]() ![]() ![]() |
I think the engine is terrific. I had six trouble free (yes!) years and am nervously comparing my new derv fuelled replacement.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
The Jag engine is better imho BUT! The big BUT is the transmission on the later Jag engine is SOOOOOOO much better than the BMW transmissions!
chawks Member Since: 28 Oct 2013 Location: Dorset Posts: 309 ![]() ![]() ![]() |
Is there a particular year they went from the BMW unit to Jag? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35766 ![]() ![]() |
this should help,
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 569 ![]() ![]() ![]() |
I spent ages looking into this & made my mind up by buying a late 2005 (2006 spec) 4.4 JAG with a 6 speed box. Nearly four years on & still pleased. |
DavidL Member Since: 14 Nov 2013 Location: wiltshire Posts: 143 ![]() ![]() |
Thanks all, so generally a positive reaction. |
quavey Member Since: 22 Jan 2017 Location: Lancaster Posts: 306 ![]() ![]() ![]() |
I wanted a jag 4.4 this time, mainly for the gearbox etc. I couldnt find one but would have much preferred it to the one I bought. 2005 E60 M5
rej Member Since: 06 Jan 2014 Location: Stevenage Posts: 496 ![]() ![]() ![]() |
I have had my 2005 Registered (2006 model) since January 2014. At the time I did not want a diesel as I was worried about the repair costs of turbos and injectors etc.. The mpg was not significantly different between an early diesel and as at the time nobody wanted big petrol engines the V8 was several tghousand less than a similar age, spec, mileage diesel so got a bargain. Bought with 93K and currently on 167K. Been serviced every 12k miles by my local garage and now by a friendly mechanic. Engine wise apart from normal oil, filters and plugs only other repauirs have been the tensioners (done early on) a leaging coolant pipe (about 2 years ago), a failed PCV last summer, o2 sensors last summer and yesterday a crankshaft sensor. Other issues have been brake lines and i had the gearbox refurbished after 18 months although i new this was on its way out when i purchased. I have also replaced many suspension arms and bushes ( i still have a low speed knock) and had about 4 sets of tyres. Most of the repairs are just normal maintenance and can be done by an enthusiast with the right info.
EnVogue Member Since: 19 Jan 2020 Location: Essex Posts: 23 ![]() ![]() ![]() |
Are the touch screen versions the ones with the Jag engine? Only reason I ask is that I have a June 2005 registered L322 and I thought it had the Jag engine as opposed to the BMW one
BMW unit...
