Home > Maintenance & Mods (L322) > dirty windscreen - interior?
nick h
2005 Range Rover Vogue 4.4 V8 Tonga Green
i notice the interior of the windscreen soon gets 'dirty'
are there any filters that could need replacing?
thanks in anticipation
Post #54055 11th Mar 2011 12:13pm
There's a pollon filter under the windscreen wiper panel
Post #54056 11th Mar 2011 12:17pm
nick h
thanks Thumbs Up
Post #54057 11th Mar 2011 12:21pm
dan_uk_1984
This often happens if the window steams up at all, as the moisture allows bacteria to grow - it's the dead bacteria that you can then see.
First of all cleanse the screen thoroughly with an alcohol based cleaner (most glass cleaners are) you should probably do this twice. Use a fresh MF cloth for each half of the screen and change between cleans so use 4 in total.
Make sure that your MF has been washed prior to this so can't have contaminants on and DO NOT use fabric conditioner on them as this ruins them. For cloths specifically used for cleaning glass put white vinegar in the conditioner drawer, and normal detergent in the other bit obv.
Sorry if the above is teaching you to suck eggs!
Obv I don't need to tell you to leave the A/C on all the time because you've heard it far too many times already Smile It may be worth checking to make sure it's working correctly though - find the high/low pressure pips in the engine bay (silver/aluminium, one small, one fat) one will be hot, one will be super cold. If no difference between the two then you need a re-gas.
Post #54058 11th Mar 2011 12:25pm
dan_uk_1984
nick h wrote:
thanks Thumbs Up
BTW - this is accessed from outside under the bonnet - be carefull with the flap that holds it in. They get sun-baked and brittle.
D
Post #54059 11th Mar 2011 12:26pm
nick h
thanks Dan
i'll use IPA to clean the glass
and excellent comment about avoiding fabric conditioner on MF cloths - i did know this from my detailing days - as the vinegar!
i wash all my 'best' MF cloths with 'Granny's' pure soap flakes (available from Tesco)
the 'dead bacteria' makes sense as it seems quite 'greasy'
Post #54061 11th Mar 2011 12:35pm
dan_uk_1984
thanks Dan
Upon your recommendation I will try this! I think you need to update the WiKi Detailing section with a "care of Microfiber Cloths" section!
Post #54062 11th Mar 2011 12:37pm
nick h
thanks Dan
thanks Dan
when i have a spare hour i'll do a write up on microfibre cloths and hopefully save people money
some sold through 'detailing shops' are ridiculously priced
i still use the yellow costco cloths for 99% of all my cleaning/detailing
i do have a couple of super dupa cloths from the US that i use for final wax polish
Post #54064 11th Mar 2011 12:42pm
nick h
any suggestions on pollen filters?
the 'powerful' one on fleabay looks good at £19 delivered and is a carbon impregnated version
Post #54070 11th Mar 2011 12:59pm
dan_uk_1984
You don't need Carbon Impregnated as the pollution sensor on the front of the car closed the outside vent whenever there are nasty smells.
Probably this one?
http://www.lrdirect.com/jmo000010-pollen-filter/ at just over £11
Post #54071 11th Mar 2011 1:02pm
How to change the filter Clicky
Post #54072 11th Mar 2011 1:05pm
nick h
thanks Dan Thumbs Up
Post #54073 11th Mar 2011 1:07pm
nick h
thanks - hence why i asked about the 'powerful' one Smile
Post #54074 11th Mar 2011 1:08pm
fair play to these chaps , they do some really good 'how to videos'.... ... - .- -.
Post #54106 11th Mar 2011 4:21pm
Powerful UK
United Kingdom 2002 Range Rover HSE 4.4 V8 Oslo Blue
Hi - thanks for the feedback on the video - not high budget productions but hopefully clear.
hope the video helps even if you don't buy the filter from us.
Just one point i wanted to add is that the carbon filter does help absorb odours that may arise from in the cabin for example if you have dogs or don't use the car for periods of time.
Hope this helps
Simon
Post #57445 29th Mar 2011 10:38pm
