Home > Technical (L322) > Limp Mode - Manifold pressure |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2929 |
So it’s in two parts then. The 5% increments are when idling?. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
16th Jan 2020 2:16pm |
“Funny you should say that” moment. I’ve noticed the same thing. I can almost say when it’s going to bong these days. The transmission seems to give a little blip before the inevitable happens. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
16th Jan 2020 2:18pm |
Nick591 Member Since: 04 May 2017 Location: Charfield Posts: 193 |
I too have been developing an increasing feeling that the fault condition might be related to gearbox function. Although fortunately (tempting fate) it hardly ever does it now I have developed a driving style which never sees me keeping the throttle pedal in a steady position when accelerating or going up a hill. Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8 |
16th Jan 2020 8:52pm |
I think mine has become less frequent due to driving style as well 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
17th Jan 2020 1:16am |
leusfx Member Since: 24 Jul 2018 Location: prague Posts: 25 |
L322 Range Rover 3.6L TDV8: turbocharger actuator arm corrosion
24th Jun 2020 12:20am |
Do you have a copy of the bulletin and parts required? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
24th Jun 2020 4:47pm |
see attached
25th Jun 2020 1:22am |
So an update:
10th Aug 2020 5:28pm |
You have the TDV8 3.6 with no DPF and with ZF6, right?
11th Aug 2020 11:46am |
All of the above is clean. There’s no set frequency to when it faults. I can go days and maybe 150 miles and it won’t fault at all. Then once it faults it’ll do it daily for say a week then stop again. It’s bizarre 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
11th Aug 2020 12:17pm |
Hi, I see now you have got the TDV8 with DPF and ZF 8 HP transmission!? Going back to original remap and EGR ON would be worth to try. BTW who did a remap for you? |
11th Aug 2020 1:08pm |
No. Mine is a 3.6 with 6 speed and no DPF. I don’t know who did the map as it was on when we bought the car. Previous owner didn’t do it (or so he says). 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
11th Aug 2020 1:24pm |
