![]() | Home > Technical (L322) > Dead parking sensors all round L322 |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4342 ![]() ![]() ![]() |
Have you had codes read with a plug in diagnostic yet? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433 ![]() ![]() ![]() |
As far as i know even 1 sensor not working will stop all.
kaoleary Member Since: 14 Sep 2013 Location: Hertfordshire Posts: 26 ![]() ![]() ![]() |
Thanks for your replies. I have a generic OBD scanner. Will that find it? |
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 546 ![]() ![]() ![]() |
No. When I had a similar problem it was the loom which had corroded. You could either get a LR code reader or try removing the bumpers and take a good look around. The damaged areas were pretty obvious. 2016 Skoda Octavia VRS Estate
Both bumpers need a little paint, so I think I'll take them off and investigate. Thanks for helpful replies |
Bloke Member Since: 13 May 2019 Location: On the road to Oban Posts: 120 ![]() ![]() ![]() |
Had the same issue, mine needed two new ultrasonic sensors on the rear.
