![]() | Home > Maintenance & Mods (L322) > Gearbox oil change or not |
| Rambles Member Since: 16 Apr 2011 Location: UK Posts: 850
When you go through the gears......this is as straightforward as ensuring you apply the brakes whilst doing so? |
| Charles89 Member Since: 11 Nov 2018 Location: Leicester Posts: 268
Yes absolutely. No need to allow the wheels to turn. It's simply to allow the torque converter to fill with oil so you dont under fill the transmission |
Thank you
| Nylands Member Since: 08 Sep 2019 Location: Somerset Posts: 200
My fullfat rr is a tdv8 2012 4.4 which is probably due for gearbox oil/ filter change. Can anyone tell me if a special tool for removal / refit of the filler plug Is really necessary. A tool re Lange Rover no 307-452 is mentioned in despatches but MD at Bristol can’t / won’t supply?
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352
Dave - take it to Cam Tech Craig’s place. Look him up on here |
Thanks for that then , I’ll check thru the membership list. Been to wet etc lately to have a look under but a good time to plan the next jobs. Spoke to nearest MD and they quoted over £200 just for the sump pan?
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35882
craig is your man,
Take it to Craig and relax knowing it will be done right and not at main stealer prices |
Thanks for the link and found his web site. I’ll give him a call next week for a chat. Mislabel at 51000 but now seven years old .
| All times are GMT |
