![]() | Home > In Car Electronics (L322) > upgrade to DAB+ |
Ansi Member Since: 07 Nov 2014 Location: Muenchwilen TG Posts: 152 ![]() ![]() ![]() |
Can you tell me which ones of the four pins are the Batt and earthpin on the Module? Don't like to do the "try and error" way. ![]() |
millerj90 Member Since: 25 Oct 2010 Location: Melksham Posts: 339 ![]() ![]() ![]() |
Ansi
Thanks for your reply, will give'm a try tomorrow. It sucks without DAB+. |
In very short term: ain’t no good!
the_ferret82 Member Since: 10 Jan 2020 Location: Hertfordshire Posts: 50 ![]() ![]() ![]() |
I recently did this module upgrade in my Jag XF. (same electronics). went from a 2 pin connector to a 4 ping and after working out JLR had swapped the pins around i got the module installed and working with ease.
You mean the one pin on the left towards the corner is the earth and the very next one ist the power or did I get this wrong?
yes the pin on the left near the corner is the ground and the pin far right is the power. the other pins are not used.
bleeperman Member Since: 01 Nov 2012 Location: lancs and Anglesey Posts: 109 ![]() ![]() |
I bought a DAB tuner with antenna and FM Tx and Bluetooth from Wish for £28 it plugs in cigar and is portable not a bad solution. |
Just gave'm an other try, no luck at all. I can "push" the DAB button but no reaction, if I push the button with the original DAB installed it would work only we do not have dab in CH only DAB+. Need the D-JV-2 module to get happy again. |
WdeRave Member Since: 25 Apr 2019 Location: Javea, Alicante Posts: 17 ![]() ![]() ![]() |
Hi Guys, I bought a DAB+ module, including bracket and custom connector converters via OLDJaguar. Not cheap, but came with a clear manual, easy to install and works flawless using the standard interface
Looks good and the perfect solution.
Mail form Feb 2019:
WdeRave
