![]() | Home > Technical (L322) > No heat after radiator change FIXED |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3239 ![]() ![]() ![]() |
Which engine! |
Muzzychris Member Since: 03 Jul 2016 Location: County Durham Posts: 27 ![]() ![]() |
Sorry! 4.4 M62 v8 2004 |
kds2 Member Since: 30 Sep 2017 Location: lincoln Posts: 225 ![]() ![]() ![]() |
Heater set to max both sides ? |
Try removing and re-fitting the pollen filter (sits just in front of and below the windscreen at the rear of the engine bay), I had the Same as you and this seemed to fix it. Probably hadn’t been seated probably? |
Thank you Dolphinboy! All sorted and have heat again! |
What was the fix? |
I tried the pollen filter with no luck, I just let it idle for about 30 minutes, still nothing. Then I gave it some big revs 3 or 4 times with the expansion cap off and that seemed to push the air through as I now have heat |
Well done. The other cause I should have mentioned was the flaps sticking. Glad you got a result! |
