Home > Maintenance & Mods (L322) > Water Pumps
Which Water Pump is best ?
AIRTEX 4124
50%
 50%  [1]
BLUE PRINT ADJ139101
0%
 0%  [0]
DOLZ L118
0%
 0%  [0]
FAI AutoParts WP6471
0%
 0%  [0]
GSF CAR PARTS 170LR005, 170LR0050
0%
 0%  [0]
JP GROUP 5414100109
0%
 0%  [0]
METELLI 24-1250
0%
 0%  [0]
OPTIMAL AQ-2326
0%
 0%  [0]
QUINTON HAZELL QCP3669
0%
 0%  [0]
UNIPART UGCGWP3072
0%
 0%  [0]
VALEO 506913
0%
 0%  [0]
HELLA 8MP 376 807-531
50%
 50%  [1]
Total Votes: 2
pcourtney
Water Pumps
anybody have first hand knowledge of what to avoid out of this little lot, I have heard Dolz are good - and Airtex to avoid, and avoid EuroCarParts and cheap Chinese pumps - so what one works well and is pretty reliable so far ?
the above are all used on the cars below Smile
Jaguar XJ Saloon 8 3.2 (1996 - 2003) 174kW
Land Rover Range Rover Sport 4.2 4x4 (2005 - 2013) 287kW
Jaguar XK 8 Coupe 4.2 (1996 - 2005) 219kW
Jaguar XK 8 Convertible 4.0 (1996 - 2005) 209kW
Land Rover Range Rover MK III 4.2 4x4 (2002 - 2012) 291kW
Land Rover Range Rover MK III 4.4 4x4 (2002 - 2012) 225kW
Jaguar XJ Saloon 8 4.2 (2003 - 2009) 219kW
Jaguar XK 8 Convertible 4.2 (1996 - 2005) 219kW
Jaguar XJ Saloon 8 4.0 (1996 - 2003) 209kW
Jaguar S-Type Saloon R 4,2 V8 (1999 - 2008) 291kW
Post #541092 19th Jan 2020 8:45pm
Dolphinboy
I replaced mine with a hella. No problems. Previous replacement Was another make, fine part or stg. Absolutely cr@p.
Top car and colour, Any pics?
Post #541123 20th Jan 2020 12:41am
pcourtney
thank you, good to know, and I have added HELLA 8MP 376 807-531 to the poll Smile
Post #541125 20th Jan 2020 12:49am
maric995
Croatia 2006 Range Rover HSE 4.4 V8 Zambezi Silver
I installed airtex water pump. The problem was in paper seal that came with the pump. Pump was leaking through the seal, so I removed it and installed metal gasket that was on original pump. Since that without problems, done 8000 km.
Be careful with the gasket, on ebay you can order just the metal gasket if the pump comes without it or with paper version. RR HSE 4.4 2006 LPG
Post #542024 27th Jan 2020 9:59am
