Home > My Range Rover > Another newbie!
EnVogue
United Kingdom 2005 Range Rover Vogue 4.4 V8 Java Black
Another newbie!
Hello all. Posted a similar one in the intro forum, but it might be better placed here. Just picked up my 2005 Vogue yesterday. It's done just a shade over 50k and has two previous owners. The car has been regularly serviced, with the last service completed last November. Just wanted to get thoughts on whether it's advisable to get a gearbox oil and filter change done any time soon?
Cheers
Post #541063 19th Jan 2020 3:42pm
rjff
Welcome EV
Nice low mileage. How about some pics?
Yep, do the oils and fluids unless it's been documented recently and you're certain of it. I think all the transmission oils are worth changing as well.
Enjoy. Cheers
Richard
Gap IIDBT
Post #541064 19th Jan 2020 4:11pm
Depends how long you plan to keep it for Whistle
As above, I'd get all the fluids changed - it's not that much money and gives you piece of mind that you've done what you can to prolong the life of some expensive parts.
Post #541066 19th Jan 2020 4:24pm
DrRob
Agreed. Dartford Transmissions and Autocare are good for tranny work. Martin Hind is your man there Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #541071 19th Jan 2020 4:50pm
EnVogue
Thanks guys. Much appreciated. Yes it's gonna be a keeper, so good to know about a gearbox oil and filter change. A pic of the Rangey above
Post #541075 19th Jan 2020 6:21pm
Drake
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
New year, new Range Rover - that's th way to beat the Winter blues. Nice car and a desirable version with the N/A Jag engine and updated electronics. Not at all easy to find in good low-miles condition now, are they?
My 2003 had 80,000 on it when I bought it and the gearbox exploded at 86,000... a truly rubbish life-span in terms of mileage that cost £2600 to put right with a reconditioned unit, torque converter and oil cooler. So yes, service it now and you'll have a fighting chance of getting past 100k without major expense. At some point when convenient, check the transmission cooler and the radiator for full function - they get blocked over time, lose efficiency and the 'box overheats which will kill it in short order. These parts are obviously significantly cheaper and easier to replace as a preventative measure if there's any doubt.
Have a great time with your new pet
Post #541083 19th Jan 2020 7:00pm
EnVogue
Thanks for the advice Drake. I'm only going to do about 2k miles annually, but you're right about preventative measures to stave off any potential pitfalls - I.e. radiator etc. Will look to get the gearbox oil and filter changed first, then get diff oils changed thereafter.
Cheers
Post #541087 19th Jan 2020 7:51pm
Drake
I see - 2000 miles p/a will definitely keep the car pretty young at heart then, plus moderate the fuel bills!
Post #541089 19th Jan 2020 8:13pm
TDSIX
United Kingdom 2011 Range Rover Vogue TDV8 Nara Bronze
That's lovely and welcome. 2010 FF 4.4 TDV8 Vogue - Gone
2007 FF VSE 3.6 TDV8 - Gone
2011 RRS HSE 3.0 TDV6- Gone
2003 FF TD6 Vogue - Gone
2006 FF TD6 - Gone
2007 FF 3.6 VSE - For sale
2011 FF 4.4 TDV8 - Current
Post #541098 19th Jan 2020 9:25pm
EnVogue
Thanks six. It's got quite a lot of swirling, but I'll get my DA polisher out and give it a mop and polish when the weather warms up a bit.
Post #541106 19th Jan 2020 10:38pm
EnVogue
Well I've been looking into the issue of getting the gearbox oil changed. Dartford transmissions will do the flush AND change the filter for £275, which doesn't seem bad at all. They said that the filter must be changed. Another place in Kettering jgs4x4, will do gearbox flush, change the diff oils for £380, but no filter change on the gearbox. They said the filter is a gauze and the flush will clean it out. I think I might just go to Dartford transmissions and get them to do the flush and get the diff oils replaced in the Spring
Post #541291 21st Jan 2020 5:00pm
