![]() | Home > Maintenance & Mods (L322) > Anderson connector from front to battery |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8093 ![]() ![]() ![]() |
On my L322 I just left it on top of the battery - didn’t really need external access -
Leesbay Member Since: 05 Dec 2019 Location: Rainford Posts: 53 ![]() ![]() ![]() |
Ideally want an external point so i can plug in and charge without opening bonnet especially if car is locked and to save faffing around with manual key opening
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3981 ![]() ![]() ![]() |
I have a crek connection cable fitted in the boot of my car with the +ve terminal connected to the cable supplying the rear fuse board and the -ve terminal connected to an earth point on the bodywork behind the offside compartment panel.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3555 ![]() ![]() ![]() |
can't you charge via the towing socket with an adaptor?
Assuming you have a towing socket...... and that it’s either a 13 pin or dual 7 pin - the single 7 pin socket doesn’t have a permanent live
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1583 ![]() ![]() |
Anderson connector fitted under the rear bumper, cables run up and through the grommet for the RH taillight assembly, then, via a self-resetting circuit breaker, to connect to the 50A cable (on the rear fuse/relay panel in the RHS rear) which connects to the main battery in the front. Ron B. VK2OTC
Thanks all
Ansi Member Since: 07 Nov 2014 Location: Muenchwilen TG Posts: 153 ![]() ![]() ![]() |
On my former 322 I had a MagCode Socket installed on the driverside (leftside) side ribs or what ever you call them.
I wouldn't attempt it. One would probably burn out the wiring. Jump start to the connection points under the bonnet. Really, how often does one need a jump start? Once every few years? Ron B. VK2OTC 2003 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
Thanks mate, your probably right, more for occasional top up charging and as long as the doors open i can jump start from battery terminals |
Jim_m_kidd Member Since: 03 Oct 2012 Location: Yorkshire Posts: 69 ![]() ![]() |
Just wondering if Alister could chip in with some more info... 😀
The earth point just screws out - the body underneath is threaded - I used a deep socket, but spanner would be fine.
Great, thanks for coming back, I’m going to take a look again tomorrow, if you can let me know about the positive that would be fantastic! |
I’m fairly sure it was undo the bolt on the top of the photo then big screwdriver underneath to pop out the fixing on the other side which just pushed back in again afterwards.
