Home > Technical (L322) > Auxiliary coolant pump & FBH
gilesharrison
United Kingdom 2008 Range Rover Vogue TDV8 Stornoway Grey
Nathan, I've just swapped my aux coolant pump on the FBH but I've got an air lock and it won't prime itself. I can here the pump running just it just gurgles and splashes.
Any ideas on bleeding it?
Post #540072 10th Jan 2020 6:42pm
Nathan v8
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
You could try back filling the fbh through the top hose inlet.
I did the normal bleeding.. cap off, bleed screw engine running heaters on full.. then run the fbh.
You might have to bleed again after this..
Post #540076 10th Jan 2020 7:18pm
gilesharrison
I'll try again tomorrow. I didn't put the heater on full last time. If that doesnt work I'll start pulling hoses and messing about.
Cheers
Post #540080 10th Jan 2020 8:15pm
TJH1985
Sounds like solid progress Thumbs Up Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Previously George a 2007 MY07 Java Black VSE 3.6 TDV8
Previously a 04 MY04 Defender 90 Sad
Post #540120 10th Jan 2020 11:45pm
Andy
I really need to get mine fixed 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #540324 12th Jan 2020 5:42pm
cass
Andy,
Appologies for going off topic but is your problem still the P023 code? if so I may be able to offer a suggested fix
Post #540339 12th Jan 2020 6:50pm
Andy
Yes. Although it’s not as frequent as it was. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #540343 12th Jan 2020 7:51pm
gilesharrison
Hi all
So I've changed my FBh aux pump. The one I got didn't have the wiring loom so I made my own one up. I presumed black wire will be negative but I may have got the polarity wrong. I Robles the coolant today following the procedure in RAVE.
I can now get the FBH to fire up from the remote. The heater starts fine, hot air from the exhaust, fan on in the cabin. Problem is that shortly after the nice turbine noise gets going, there's a sort of funny squelching noise and the FBH powers down.
My thinking is the coolant flow isn't working and the FBH soon overheats and shuts down.
Incidentally, when I start the engine (cold start) the FBH starts and runs fine.
Any ideas? Suggestions? Diagnostic ideas?
Thank you!
Post #540367 12th Jan 2020 10:25pm
Nathan v8
That’s the same problem I had that sound is the coolant boiling in the fbh..
I would swap the polarity and try it can you power the pump up with out the fbh just to test it I assumed the same as you but when I tried it the pump did not run.
Swapping it sorted it and it’s been working fine.
Post #540574 14th Jan 2020 5:27pm
gilesharrison
I've not had chance to try it yet but I'll swap the polarity round, hopefully it'll sort it.
Do you think I found get the battery out and reach down to the wiring from the top? Might be quicker than going in through the wheel arch again.
Post #540626 14th Jan 2020 11:53pm
gilesharrison
Swapped the wiring round. All sorted! I now have fully functioning park heating from the programme function or the remote.
Thanks for the help. Happy now!
Post #541192 20th Jan 2020 3:48pm
gilesharrison
So for reference, the black wire is positive to the FBH coolant pump, negative is mustard yellow.
Post #541193 20th Jan 2020 3:49pm
TJH1985
Thumbs Up I think this is one of the most common failures with the FBH was n the L322. Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Post #541235 20th Jan 2020 10:42pm
