![]() | Home > Maintenance & Mods (L405) > Replacing door Mirror ££££ |
| Doodle Member Since: 02 Nov 2013 Location: Midlands Posts: 127
Mirror hit by approaching flatbed. Glass broken into three pieces. No damage to mirror shroud.
| Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3278
Have you looked on Fleabay or Amazon? I bought mine for £17 (for an L322) when the retail was nearly £90!! |
| CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1431
No experience of 405, but based on 322 prices that sounds about right. I had reversed a mirror into a tree |
| Big Boy R44ROV Member Since: 14 Nov 2011 Location: Chadderton, Oldham Posts: 556
Sounds about right. I paid over£190 for the n/s mirror. Because they are electrochromic it ramps the price up massively. Tony
| supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3962
Rather than start a new thread today I kissed wing mirrors |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35872
have you tried sophie at duckworths....she'll probably ask for the vin so that you get the correct mirror.. ... - .- -.
Thanks Birthday boy - I've popped Sophie the question |
when you get the replacement make sure you screw in on properly, you dont want it to fall off when you go down the road..
| Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16403
Indeed you have got a good memory, I still miss that car. I assume l405 and l454 (Sport?) are interchangeable. Geoff |
& D4 Facelift |
Just bought a stick on one to be going on with. No reply yet from Sophie. There is a left hand one on Ebay for 100 quid so dependent on her reply and if the stick on one is any good I'll keep it and keep an eye out for a secondhand one. I realise I'll lose all the functionality but it was only 7 quid I suspect a new one might be significantly more expensive. Geoff |
Still no reply from Sophie - is this what I need ?
| Spooky Member Since: 03 Aug 2009 Location: Swindon, Wilts Posts: 190
Yep - that should fit your AB. Regards,
'Bertha' - 2014 SDV8 Autobigraphy
