Home > General > Help me out the wifes on my back!!
Ludzy
United Kingdom 2005 Range Rover Vogue SE Supercharged Zambezi Silver
So just got home and the wife informs me that our newly replaced steering column (see my other thread) "doesn't rise up like before"? Now I have the steering wheel set to it's highest level and seat to the highest aswell and to me it's the same. If at all possible could somebody take a pic of there ffrr steering column set to it highest position so I have something to go on. I looking for the actual gap where the leather cover wrinkles up as the wheel moves. The wife convinced that there was no gap before!!!
I'll try to get a pic of ours and post.
Cheers
EDIT
Heres the pic. She says that the gap wasn't there before. She has wheel out but higher apparently.
Post #54143 11th Mar 2011 6:58pm
dan_uk_1984
That does look low. It looks like they haven't adjusted it correctly.
Can't you take it back and ask them to sort it FOC of course!
Failing that you can often edge it up by tapping the lever. Mine used to do this, I had to wedge my knees under the wheel and lower it but stop it lowering with my knees so it stalls if that makes sense. It would then go up another inch! I had to do this a few times. (try this at your own risk, I wouldn't want to be responsible for damage)
Then Make Sure you store the memory position or it will drop down as soon as you start the car next.
D
Post #54155 11th Mar 2011 9:19pm
JustinP
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
Have you adjusted the forwards / aft position, to see if that gets it back to how it was before?
Here's mine at the up and out.
and heres it up and in.
Yes I know the car needs a hoover and fuel Smile
Gone - Range Rover Supercharged 2006
Post #54156 11th Mar 2011 9:28pm
Ludzy
Yeah tried that. Here's a pic from the side with the wheel set to the max on up/down and in/out.
So does it look wrong?
Post #54159 11th Mar 2011 9:49pm
Looks right to me
Post #54187 12th Mar 2011 8:36am
Ludzy
Hmm strange then. Just sat at the garage now as there having a look. Apparently there is a adjustment.
Cheers
Post #54191 12th Mar 2011 9:00am
Ludzy
Problem/confusion solved.
There new column that was fitted just over a week ago was the most up to date part. LR have changed the column afew times since it first came out to try and solve the nylon bush problem and jamming issues. to do this they made the brass spinning rod (which controls the up/down movement) 8mm longer to prevent any jamming. In doing this the rise height has about an inch less up range. So with the original 05 column I had more movement but was more prone to fail. The latest edition hopefully shouldn't do this.
So the wife was right......kind of!
Cheers for the pics
Post #54196 12th Mar 2011 10:29am
Duh - the wife is always right did she not tell you that....... Rolling with laughter
Post #54200 12th Mar 2011 10:45am
Emperor Mong
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Loire Blue
Post #54240 12th Mar 2011 2:19pm
Ludzy
So just got in the car since Saturday and the drivers seat and wheel adjuster has no power what so ever so cant change memory setting or tinker with the seat and wheel position. I'm assuming that this area has no power as the red memory light does not even come on. Any ideas????? Fuse maybe???
Post #54887 15th Mar 2011 9:49pm
Any connections under the seat loose ====================================
Post #54888 15th Mar 2011 9:51pm
Ludzy
no all connections are solid. Wheres the fuses for these, and do the drivers seat and steering column on the same fuse?
cheers
Post #54893 15th Mar 2011 10:13pm
fuse locations could be in the manual or on rave.. ... - .- -.
Post #54896 15th Mar 2011 10:18pm
Ludzy
Yeah just looking at rave now. Seems to be in the passenger fuse box. I'll go and have a look...................................?
Post #54897 15th Mar 2011 10:22pm
Ludzy
The fuse for the drivers side switch pack had gone so just swapped it for the passenger for now so all good. The steering wheel relay fuse is fine also but still no movement from it???? I hope it aint another trip to the garage that change my column. Dont know what else it could be?
cheers
Post #54902 15th Mar 2011 10:38pm
