Home > Technical (L322) > Is this normal? - EGR Temp?
M@r]{
United Kingdom 2012 Range Rover Autobiography 4.4 V8 Barolo Black
Hi All
When I look at the temp of my EGR sensors (4 of them) one just continuously states 100. This feels like the reading it would give by default. Can anyone else check theirs for me?
Mine is a 2012 TDV8
Thanks
Post #541592 23rd Jan 2020 3:00pm
Baltic Blue
Does this help ?
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #541597 23rd Jan 2020 3:10pm
M@r]{
Yes thank you. Just confirms I have yet another problem I need to deal with. My first toe dip into the water of RR ownership is going to be a short lived one at this rate.
Does anyone know how difficult it will be to replace this "Bank 2, Sensor 1" sensor? I had "Bank 1, Sensor 2" replaced about a month ago? That was showing large spikes in temp and causing a Restricted Performance warning.
Post #541610 23rd Jan 2020 4:44pm
Baltic Blue
Caution !,
I have other screenshots showing 100c.,
This one showing an active regen in progress....
If it is not actually causing you a problem, investigate more about what it is monitoring before changing it ??
Post #541613 23rd Jan 2020 5:06pm
Dolphinboy
IIRC the bank 2 sensor is only for the second turbo and so only goes up on the very few occasions that the revs get over 2500 Cool
Mine has always read 100. (2011 tdv8) so don’t worry about it.
Post #541614 23rd Jan 2020 5:23pm
DrRob
Boot it above 2500rpm and it should climb up in value Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #541619 23rd Jan 2020 6:05pm
Range Rover L322
An IIDTool will tell you if the sensor is broken but as Dr Rob infers the Bank 2, Sensor 1 is the sensor on the second turbo which only spins up when you boot the throttle. Usually it sits at 100°c as the default reading.
Why do you want to know this temperature? If you are gauging the DPF regen temps the most reliable and accurate temp sensor is Bank 1 Sensor 2 which will go up to 640°-660° on an active regen.
Even if the Bank 2 Sensor 1 sensor is broken i would not worry too much about it. I learned early not to fix things that weren't broken or important as it just gets expensive... for stuff you don't actually need. This model has so many sensors...
hope that's some help...
cheers
Post #541812 25th Jan 2020 12:42am
