![]() | Home > In Car Electronics (L322) > Charging points for 2011 tdv8 battery? |
Bradders Member Since: 03 Dec 2018 Location: Gods own country Posts: 417 ![]() ![]() ![]() |
Red lead to the positive battery terminal and the black to un unpainted bit of chassis. I connect mine to one of the unpainted strut bolts. Current: FF Westminster money pit
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3875 ![]() ![]() ![]() |
I have one of these Ctek leads permanently wired to the battery cable in the rear fuse box cubby. and a convenient earth bolt next to it.
Think it maybe a problem with your charger James? |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 700 ![]() ![]() ![]() |
One assumes your charger has enough amperage?
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3261 ![]() ![]() ![]() |
Thanks everyone for your advice. Charger works fine on both my other cars. Think it may be the neg pole which is not allowing a charge to go through. I will look for an unpainted bolt to attach to.
fenlander Member Since: 14 Jan 2020 Location: Norfolk Posts: 124 ![]() ![]() ![]() |
On my 2002 V8 petrol/LPG, I really like the "reverse charge via towbar electrics" method - assuming you have a 13 pin fitting (I believe one of the 7 pin varieties also works) see https://www.disco3.co.uk/shop/tow-electric...c-p45.html |
The NEG point from the pre 07MY is still on the top of the passenger strut on your 2011MY James... |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4345 ![]() ![]() ![]() |
Craig - can I confirm my understanding that the negative terminal on a 2011 tdv8 grounds onto the passenger side strut ? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
DrRob yes-ish sir! The battery won’t solely ground there sir but I believe (from memory) the ground stud has never been removed in later models... Does that answer your question? |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3983 ![]() ![]() ![]() |
At 11.8V it's possible a smart charger wouldn't detect it is connected to a battery and so not start the charge process.
Thanks again all. Success! Used the same nut (photo to follow) as on previous models only there’s no neg wire running to it.
No James, they took the + peg away when Ford owned them sir... |
Thanks Craig |
