![]() | Home > Maintenance & Mods (L405) > Oil on a bolt...assuming this is bad? |
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352
Does it feel like engine oil or transmission oil?
| Dixy Member Since: 09 Apr 2009 Location: Somerset Posts: 1123
All Land Rover products are designed to seep oil as a way of marking their territory.
| jackcramerr Member Since: 13 Oct 2019 Location: London Posts: 220 |
How many miles has it done?
| pherplexed Member Since: 27 Apr 2010 Location: SC, USA Posts: 70
Only has about 28k on the clock. 2021 P525 | Eiger Gray |
| JST Member Since: 12 Dec 2013 Location: Somerset Posts: 502
Looks like engine oil then, oil and filter changed on it recently.
Buy some decent ramps and get under it and whip off the engine guard |
No oil change recently, but just went back through service records to see what was done last. Totally forgot they had to fix a very small transmission case leak under warranty about 6 months ago. It wasn't something I ever saw or knew about, just something they noticed while fixing a suspension issue. There was a TSB that called for using a putty cement to fix...something the master tech was verbally skeptical of that it could be a permanent fix. So if this is the transmission case I'm looking at, it's either leaking again or it's just residue from when they fixed it, presenting itself after a car wash the day i took those pics. 2021 P525 | Eiger Gray |
