Home > Technical (L322) > L322 Continuous Beep at motorway speeds
pcourtney
Yesterday driving home on the motorway, needed to accelerate to overtake, accelerated quite hard (kick down) and within seconds got a continous beep sound, have uploaded this to youtube
pulled over at the next exit, turned off the engine and waited for 30 seconds, the beep sound gone and I carried on my journey, after 10 mins or so I needed to accelerate again and the beep sound came back, stayed on continously even when slowing down, so pulled over again, turned off engine and then back on again, luckily I was not too far from home by then
have spoken to my local Land Rover main dealer this morning, and they are clueless, so can anyone on fullfatrr give me some ideas, there were no warnings on the dash, no lights flashing at me, nothing whilst driving with the beep going on, and cannot see anything in my L322 manual, and nothing when I google for this Rolling Eyes
Post #542241 29th Jan 2020 11:41am
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
Its not a speed warning is it?
Post #542249 29th Jan 2020 12:08pm
pcourtney
no, the beeps carried on while I slowed down to 50mph, and still carried on till I came to a stop
and no info displayed on the "Message Centre" either
Post #542250 29th Jan 2020 12:15pm
fenlander
England 2002 Range Rover SE 4.4 V8 Tonga Green
Sounds like the hidden JLR AI function that assesses your driving ability and recommends a safe speed Whistle "Gloria" 2002 L322 Voguish V8 LPG - carcass
"Jessica" 1996 Disco 1 300 TDi Auto
"Harriet" 1994 Disco 1 300 TDi Manual - Gone
"Daisy" 1992 Disco 1 200 TDi Manual - Gone
Post #542265 29th Jan 2020 1:16pm
pcourtney
maybe maybe - but even when slowing down to 20mph, then to 10mpg and to a stop, it was continuosly beeping till I turned the engine off - any ideas folks Rolling Eyes
Post #542334 29th Jan 2020 10:06pm
fenlander
Have you got any IIDTool or equivalent to run some live value tests ideally, or just read faults, clear faults, read faults etc? "Gloria" 2002 L322 Voguish V8 LPG - carcass
Post #542342 29th Jan 2020 10:52pm
pcourtney
my mechanic put his Snap On Verus on the car back on the 16th Jan, but no faults came up Smile
we thought it might find some things on the auto gearbox, but nothing, but I have already decided to go for a full flush and 10L oil change
Post #542346 29th Jan 2020 11:14pm
MarianaWestminster
Does your car have lpg fitted by any chance?
I wonder if its beeping to tell you its switched back to petrol (due to accelerating for overtake)
Just a thought.
Post #542361 30th Jan 2020 1:08am
pcourtney
yes you are right
it has a Prins VSI system - but they are supposed to be good, one of the better ones, maybe it needs another service
is this a common thing for us LPG users that hard acceleration is not really possible with LPG systems ?
maybe I need a switch that can toggle between LPG and Petrol Whistle
Post #542362 30th Jan 2020 1:32am
Gazcw
United Kingdom 2011 Range Rover Vogue TDV8 Baltic Blue
I ran an X5 with lpg and the tank level indicator was also the switchover if you wanted just petrol. It will switchover under hard acceleration if there is not enough pressure to get the gas into the injectors quick enough I believe. Was it nearly empty?
Post #542368 30th Jan 2020 9:07am
pcourtney
yes it was fairly low, the indicator showing 10 to 20% left in the tank I reckon, I will fill her up today, and when I go back home give it a blast and see if the beeping comes back on again - hopefully it is nothing more sinister than this
Post #542399 30th Jan 2020 12:00pm
Gazcw
Is it a relatively new install? Injectors may be undersized for the engine size but I reckon it was levels that were issue.
Cheap fix at least! Hopefully Thumbs Up
Post #542401 30th Jan 2020 12:03pm
Dolphinboy
Well spotted Mariana. Think you may well be right. They do ping when low or switching to petrol, especially under acceleration.
OP, you should think about having your lpg serviced before you do anything else. Should be done annually or every 200 hrs or so (mine’s a STAG system)
Post #542411 30th Jan 2020 12:33pm
