Home > Technical (L322) > Restricted Performance Red Light
Page 1 of 4 1234>
jackie-o
Netherlands
Hi,
So more problems with my lovely 2011 4.4 TDV8 (70.000 miles)
I was acceleration to 70 mph and once there i felt a small "judder" as 8th gear clicked in. Immediately after I got a red restricted performance light.
I slowed down and drove 5 minutes to the nearest garage I could find. The last few 100 yards were lights, speed bumps etc and after each acceleration there was a clear "whining" noise coming from the engine. sounded almost like a cat....
Car was hooked up to diagnostics in the garage and threw up (amongst other things) 7 fault codes under engine management;
Some fault in turbo B
Something with air mass flow
something with temperature
water in fuel sensor
The idiot mechanic deleted all fault codes before i could copy them as he said one fault can cause another and so on.
We started car up again and now it did not show any faults. Drove approx 1 mile home without issue.
Any ideas what this could be and do I dare drive around in it? Or should I just take it to nearest LR dealer?
Oh, and the car has an oil leak and smells of burnt oil after driving at motorway speeds...
This car has so much charachter Rolling Eyes
As always, very grateful for any replies! RR Vogue 4.4 TDV8 - 11
Toyota Land Cruiser Prado - 02
LR Discovery 4 SDV6 -11 - Gone
RR Vogue 3.6 TDV8 - Gone
Post #542228 29th Jan 2020 10:10am
GGDR
The ECU records every momentary error.
Clearing codes then seeing what returns is the typical process in my experience.
Others may correct me here.
I would keep going and monitor.
I'd also order a fault reading device. Ideally an IID Tool.
The IID's are expensive but hold their value.
And it means the 'character' of your car can be analysed at any moment!
. Cheers, Greg
Post #542230 29th Jan 2020 10:33am
jackie-o
Netherlands
Thanks Greg,
Would just have been useful to copy old fault codes before he deleted them to compare what comes back.
I guess I will keep driving and see what happens...
Will order IID tool asap too.
Should be an interesting next few days Confused RR Vogue 4.4 TDV8 - 11
Post #542237 29th Jan 2020 11:09am
jackie-o
Netherlands
Btw, any idea what the "whisteling/whining" noise could be? RR Vogue 4.4 TDV8 - 11
Post #542245 29th Jan 2020 11:58am
DrRob
Get it to a LR expert and diagnose the leak. Could be a failing turbo Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #542248 29th Jan 2020 12:06pm
jackie-o
Netherlands
Booked at LR main dealer tomorrow morning, hope to god I dont need to change any turbos Big Cry Big Cry RR Vogue 4.4 TDV8 - 11
Post #542282 29th Jan 2020 3:24pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
Could it not be the 4 short hoses on the intake? BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #542283 29th Jan 2020 3:32pm
jackie-o
Netherlands
AJ, Sounds preferable to a new turbo...
I just drove approx 15 miles, carefully not revving above 2.000 rpm.
Yellow restricted performance light came on straight away but at least it wasn't red Very Happy
Drove so carefully that I cant say if the performance was actually restricted but no strange sounds this time. RR Vogue 4.4 TDV8 - 11
Post #542284 29th Jan 2020 3:37pm
AJGalaxy2012
Have a look here https://www.fullfatrr.com/forum/topic26796-30.html
Im only thinking the noise could be air escaping when on boost and the limited performance because of insufficient boost? BMW i3 Electric Car
Post #542288 29th Jan 2020 4:30pm
DrRob
Oil leak could be the oil cooler gasket or the 2 o rings on the pipe into it. Lots on here. Easy to diagnose.
Look in wiki for oil leak topic under Engine section Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #542302 29th Jan 2020 6:33pm
jackie-o
Netherlands
@ Rob, last garage diagnosed it as the oil cooler gaskets but only that the car was "sweating" oil so thought I´d have it fixed and next oportunity, let´s see if the main dealer comes to the same conclusion...
@AJ, thanks for the link, could be it as red light came up just after acceleration.
Waiting at dealer now for the verdict RR Vogue 4.4 TDV8 - 11
Post #542370 30th Jan 2020 9:36am
mpirie
If you get a chance, take the engine cover off and shine a torch into the middle of the V of the engine.
If you see oil then the cooler is leaking. If you don't, then it's likely to be the O rings on the rear oil feed pipe.
BTW, the second turbo on the 4.4 doesn't really get going until 2500 rpm, so staying below 2000 rpm may have stopped the warning turning red.
Mike
Post #542380 30th Jan 2020 10:22am
jackie-o
Netherlands
Thanks mrpirie.
So from reading the various forum threads i can read out four types of oil leaks?
* Oil cooler gaskets
* Cracked oil cooler
* Oil pump
* O-rings on rear pipes
While the mechanics have things taken down, does it make sense to change parts as future prevention? I.e save some money/time on work that will need to be done at some point anyway? RR Vogue 4.4 TDV8 - 11
Post #542384 30th Jan 2020 10:29am
GGDR
How many miles on your RR jackie?
Over 80k you might want to think about changing the idler pulleys.
. Cheers, Greg
Post #542386 30th Jan 2020 10:34am
jackie-o
Netherlands
Greg, it´s almost exactly at 80k miles but belts and pully´s were already done 2 years ago : )
Just got the car back and all fault codes gone exept for water in fuel sensor which was traced to mice chewing on the cables about 4 inches from the sensor....hopefully easy fix
Oil leak clearly from from the V so I hope new gaskets will sort that.
They did find an air leak coming from the back of the engine - they suspect the EGR but needed to remove air intake manifold to check further. This is likely cause of previous fault codes...
They estimate 2 hours of work to strip down and give exact cause of air leak and oil leak
Any first thoughts on the air leak? Sounds like it could be the 4 intake pipes as per link from AJ? RR Vogue 4.4 TDV8 - 11
Post #542394 30th Jan 2020 11:39am
Page 1 of 4 1234>
