Home > My Range Rover > Gloria goes for First Proper Journey |
jim4244 Member Since: 31 May 2012 Location: UK Posts: 843 |
I would check the gearbox oil level and would also be tempted to squirt a tube of Dr Tranny in to see if that would help.
2nd Feb 2020 10:16pm |
fenlander Member Since: 14 Jan 2020 Location: Norfolk Posts: 124 |
Thanks Jim
2nd Feb 2020 11:48pm |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3058 |
Oil cooler always a good idea to do. Also try flushing your radiator through. The bottom bit cools the gearbox and fills with sludge thus reducing cooling. Plenty on Here about it. |
2nd Feb 2020 11:54pm |
Much appreciated DolphinBoy "Gloria" 2002 L322 Voguish V8 LPG - carcass
3rd Feb 2020 12:29am |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 648 |
Sounds like your transmission fluid is overheating so the clever ECU is implementing its cooling strategy mode that keeps the engine speed (and therefore the pump flow) much higher than normal - this happens because at low revs the pump flow is working at 20% and this is not keeping your transmission fluid cool enough !
3rd Feb 2020 11:30am |
@PC
3rd Feb 2020 2:18pm |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1227 |
We have a 2003 4.4V8 L322 and exactly the same thing happened. When I did some searching on here I discovered that between a certain VIN range (ours was in that range) the radiator had a known problem where the bottom 6 rows would collapse internally blocking the fluid flow to the gearbox cooler.
4th Feb 2020 1:20pm |
Very helpful thanks Paul, my VIN is in this range so new rad it might be!
4th Feb 2020 8:17pm |
Great explanation thanks PC "Gloria" 2002 L322 Voguish V8 LPG - carcass "Jessica" 1996 Disco 1 300 TDi Auto "Harriet" 1994 Disco 1 300 TDi Manual - Gone "Daisy" 1992 Disco 1 200 TDi Manual - Gone |
4th Feb 2020 8:18pm |
We had ours done by a gearbox specialists in Westbury. As far as I know they replaced the radiator with an OE unit and put in a new transmission oil cooler as well.
4th Feb 2020 11:54pm |
yep, my vin is 165xxx - and the bottom 6 tubes were shot to pieces
5th Feb 2020 12:01am |
Very nice that Direnza Rad
5th Feb 2020 12:37am |
it is high at 108c, it should nearer 100c
5th Feb 2020 1:05am |
Yes, hopefully get some answers on your last list soon and will report back here on the findings.
5th Feb 2020 3:16pm |
