Home > Maintenance & Mods (L322) > Torque Converter gone...?
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
And a firm in Harlow that will road test it and plug it in to see what fault codes are reported..
Is it me or am I just being fobbed off with people wanting to just guess and change parts to see if it fixes the issue? Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #444440 13th Jul 2017 9:10am
GGDR
Worth a trip up to RRPhil then Ash?
. Cheers, Greg
Post #444442 13th Jul 2017 9:22am
comports
Update - Took it to an auto specialist over near Harlow and he couldn't really feel much by way of vibration.... So for now he said it's worth adding a tube of "Shuddderfix" and see how it goes.
He said if it is the TC the shudder etc will come back and at that point a new TC will be required. For now it has totally cured the shudder and it drives fine again (but I'll not hold my breath) Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #445602 24th Jul 2017 8:15pm
Rich_Allen
I have used 'Dr Tranny Shudder Fix' in several sports and discos in the past and its amazing stuff... Normally get another 20k out of the torque convertor before needing to replace Thumbs Up
Post #446507 3rd Aug 2017 12:40pm
sako243
Ash I'm pretty sure the IID Tool will capture the data you need.
If you don't have one then you're welcome to head my way (maybe another shoot?) and we can plug in mine. You might need to buy another unlock code for your VIN (10s of pounds rather than thousands) to get the full diagnostic capability.
I'll try and remember to take a look in the morning to see if it can get the same data as what Phil showed. Ed
Post #446682 4th Aug 2017 10:52pm
comports
Sorry to pull up and old thread..... But I Have my shudder back again - 3 years down the line and 30k miles more on the clock.
It only tends to happen on light acceleration, when approaching 2,000 revs.
Interestingly I get shudder in Sport/command shift mode as well- I think I read that its not likely to be TC as there is no LUC going on in Sport..??
I’ll try to take IID readings under normal driving (if I can record it somehow) and post up here - tickover showed no real difference in injectors readings but it only seems to happen under some load.
I will check again for calliper sticking (rear only..?) to discount that.
Anything else I can check for?
As always - Massive thx to the forum.. Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #542801 2nd Feb 2020 8:16pm
dexion7
2010 Range Rover Vogue SE TDV8 Alaska White
chuck some more shudder Wink fix in
Post #542810 2nd Feb 2020 10:13pm
Andy2986
United Kingdom 2011 Range Rover Vogue TDV8 Barolo Black
Hi,
I’ve used LRS Engineering in gosfield ( Essex )
It’s not all that far from Chelmsford.
I’ve found them very helpful and honest.
They have worked on both my 4.4TDV8 and my P38 4.6.
(That’s if you have had no joy so far )
Andy
Post #542816 2nd Feb 2020 10:49pm
comports
So I plugged IID in this evening to pull some values
I got the below on idle
But on revenge th energise they all just went to 1000 exactly- something seemed wrong there. Do I need to actually driving (rather than just raving in park) to get a value.?
Also - how true is the “you won’t get LUC judder in sport”..?
Thanks
Ash Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #542918 3rd Feb 2020 9:58pm
DrRob
Give Martin Hind at Dartford Transmissions and Autocare a call Thumbs Up
Gearbox specialists Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #542919 3rd Feb 2020 10:10pm
comports
Sorry chaps
Anyone able to comment on the use of Sport/command shift mode.. I still get the same shudder albeit at a slightly higher rev range - does this point to it not being the LUC.?
Also - Any idea how I use IID tool show the injector offset when driving - I want to see if any of the injectors are not working correctly when driving.?
Thanks Gang Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #544295 18th Feb 2020 1:59pm
Kevio
United Kingdom 2012 Range Rover Westminster TDV8 Java Black
I had an oil and filter(sump) change less than 100 miles ago and had a loss of power and high revs going round a roundabout then was coming home from collecting the kids and got the judder until i eased off the power. Will ring the garage that did the job in the morning. Have they f@@ked my gearbox. Its a 8hp70 on a 4.4 tdv8.
Post #545148 25th Feb 2020 7:47pm
Gazcw
United Kingdom 2011 Range Rover Vogue TDV8 Baltic Blue
comports wrote:
Sorry for the delayed response.
I checked the callipers and none of them seem to be hotter than the others but its but i was by no mean scientific about it.
Is there an accurate way to diagnose it if it is the TC. I'm going to take it to Gratech in Maldon tomorrow but would be keen to know if they would be able to diagnose it rather than guess..
I don't really want them changing parts without knowing if it will fix it.
Any ideas?
Thanks gang
My sticking caliper was noticeable more at 50-70 and the heat generated was obvious in the alloy wheel. I could feel the heat on my hand without touching it. 2011 4.4tdv8 Vogue
Baltic Blue
Post #545169 25th Feb 2020 10:07pm
