![]() | Home > Maintenance & Mods (L322) > Heating and A/C vents |
sportin Member Since: 12 Mar 2011 Location: USA Posts: 26 ![]() ![]() ![]() |
Hi everyone new here....got a weird problem...
You need to leave the A/C on all the time, it is climate control, it's designed to be left on and you set the temperature. Leave it on and see how it behaves then, it's quite clever and trys to "out think" you sometimes. For example if the coolant in the heater matrix isn't warm in won't blow to the vents or feet if it's cold in the car... ![]() |
I was trying to conserve fuel...so I thought by shutting off the A/C and just using the traditional heating, method, basically not using the A/C function for heating, that it would work, and that I should be able to select the vents. I guess this another one of those little functionality things you tend to figure out along the way while owning a RR.
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 ![]() ![]() |
The FFRR experience is anything but straight forward. World of its own, on so many levels.... |
It's worth remembering that the A/C does more than just cool the air when it's hot outside. In winter it comes on and off to de-humidify the air inside the car - without this you can expect electrical gremlins across all the car's systems. It is also used to balance the temperature of the air when you set the dial to the desired temperature. ![]() |
I know this is blatant thread hi-jacking but on some mornings when I start up I see my AC has turned itself off along with auto control of inside/outside air and only partial climate control I,e only the LED bar is lit and not the dot above it on the switch what do we think is going on it's head ? 2008 MY Supercharged
Mine did this when the blower resistor was messing me around. ![]() |
Thank you...you make valid points. The one thing that I didn't take into consideration was the dehumidifying effects of the CC.
They are part of the "forced air ventilation system" I think the air exits through them as the rest of the car is relatively well sealed, if they weren't there and you had the fan on it wouldn't work very well due to the build up of cabin pressure. ![]() |
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 ![]() ![]() ![]() |
My guess is that they also stop the windscreen blowing out when you slam the doors. ![]() Gone - Range Rover Supercharged 2006 ![]() |
Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181 ![]() ![]() |
And it is cheaper and less troublesome than making all the windows drop a fraction and then re-close whenever you open and close a door. 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
That being said, if I have passengers getting in my car I have got into the habit of leaving my door to be the last one closed otherwise none of them can shut their doors on the first go! ![]() |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1762 ![]() ![]() ![]() |
I'm gonna adopt that stance as well Dan. Fed up of shouting at folks... "Whats the matter with you. Can't you even close a door properly..!"
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6374 ![]() ![]() ![]() |
My old RRS was so pressurised it would crumple my water bottles all the time, one guy I knew who also had one said a football burst inside his car! Discovery 4 HSE
