Home > Technical (L322) > Wheel well water ingress and offside rear fuse panel issue |
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 |
5th Feb 2020 2:46pm |
Yes, It is normally very clean and dry. To me, it is as if something is fizzing due to a bad connection coupled with damp/water ingress although there is no smell. I have yet to start stripping back the plastic surrounds.
5th Feb 2020 3:47pm |
Panic over. It is cement dust (Doh)! Will keep an eye on the water situation. Previous cars:
5th Feb 2020 3:50pm |
dennij Member Since: 24 Feb 2019 Location: Up North Posts: 450 |
Well I would class that as a result, better it's cement dust than something catastrophic |
5th Feb 2020 4:12pm |
jaysta10k Member Since: 24 Aug 2017 Location: Cheshire Posts: 294 |
I had some problem with a lot of water ingress into spare wheel well with the wheel out I could see that water was creeping in from either corner at the front of wheel well it transpired it was the upper tailgate fixings so I plastered them in silicon seems to have cured it. Thses cars are a pain in the arse for leaks!! Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
6th Feb 2020 4:20pm |
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 428 |
I had an issue with the vehicle forever misting up. 1" water found in wheel well. One 3mm hole later and done! Cheers
6th Feb 2020 5:45pm |
