![]() | Home > Technical (L322) > Clicking sound from rear nearside |
jim4244 Member Since: 31 May 2012 Location: UK Posts: 853 ![]() ![]() ![]() |
I believe that it is the second fuel pump?
Chlorothalonil Member Since: 08 Sep 2018 Location: East Yorkshire Posts: 54 ![]() ![]() ![]() |
Is that for the FBH? Is there any way of fixing it? Thanks. |
So apart from the ticking noise is everything working as it should? |
Seems to be. |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1197 ![]() ![]() ![]() |
Sounds like the FBH pump. Clicks about once per second then moves to about twice per sceond if the FBH demand goes to full. Should run from this time of year cold until the engine coolant reaches a predetermined a set point.
Not on the timer and don't have the remote unfortunately.
Not sure of you can enable the park heating timer on yours, someone on here may be along to say if it'spossible. The WM in the Wiki may help.
Thanks, I will double check and see what it does when it has been on s run. Not bad it long. Good to know the clicking isn't unusual. |
