![]() | Home > Technical (L405) > MY 20 TDV6 coolant low problem |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6431 ![]() ![]() |
Dearie me, even the brand new ones..... |
smakil Member Since: 31 Dec 2019 Location: Manchester Posts: 12 ![]() ![]() ![]() |
Hi.. I picked up MY14 TDV6 a month and a bit ago, I too had similar message thrown at me, initially I disregarded the message and thought it would just go away because it was only 10/12 days in of owning the FF, I called the Land Rover road assistance and the assistance arrived within 1-2 hours, the chap did a quick diagnostic and nothing was detected so then he checked under the car bonnet and he confirmed that there is a leak in the pipe which is connected to coolant tank. Luckily the vehicle was under warranty and this part was replaced, since then no issues. Please do not drive the car if you are getting this message, I was advised this because if you do this can damage the engine, which can lead to more problems. All the best Current
TDV8_Tommy Member Since: 20 Feb 2019 Location: Pinoso, Valencia Posts: 438 ![]() ![]() ![]() |
I had this warning for a while. Fitted a new coolant level sensor which didn’t change anything.
