![]() | Home > Maintenance & Mods (L405) > Prev owner extended period driving locked rear diff. Issue? |
| horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863
would an effect be a occasional rocking sensation side to side?
| GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2771
The centre diff and rear e-diff if it is fitted are electronically controlled. I hadn't previously heard of the driver having any control over the rear e-diff but at most will be to enable or disable electronic locking. In some situations a partially or fully locked rear diff may possibly have some adverse effects so LR may have decided to give the driver the option of disabling the electronics. LR would never give the driver the option of locking the diff then allowing the vehicle to be driven at speeds above a very slow pace because the handling effects would be dangerous, let alone the strain on the diff itself if used on a hard surface. |
^^ is that your beliefs or facts? You’re saying the “Electronic” button in the 4x4 menu to lock/unlock isn’t locking/unlocking when it’s pressed?? the G63 allows you lock all three (front, middle, rear) at the push of a button on the dash. Given that I don’t see why it’s not possible for LR to do the same. 2014 FF Autobiography 5.0 SC
The rear diff is either the open style or the electronically controlled variable slip (e-diff) which is standard fitment if the engine is the 5.0 SC. For other engines the rear e-diff may or may not be optioned at build time. The centre diff fitted to all L405s is electronically controlled variable slip and the front diff on all L405s is open style. I am very familiar with LR's e-diffs, having retrofitted a factory e-diff to my 2012 L322.
I'm only concerned about the 5.0L SC ATB on the L405 for the purposes of this thread. I've never used the 4x4 screen/buttons on the NAV to lock/unlock the diffs (vehicle is still new to me)...looks electronically controlled to me given these buttons. Unknown if there is an issue that the rear showed locked and have been driven that way. 2014 FF Autobiography 5.0 SC
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874
does it show 'locked' on all your types of journeys? ... - .- -.
I just stumbled across the menu while I was playing with all the options....didn't know it was even set to locked until I found the screen....so I'm uncertain how long it was "Set" to locked by the previous owner. I just picked it up about 2 weeks ago and have maybe put 50 miles on it. 32k miles on it total. It jumped out at me being set to locked once I found the 4x4 menu as I also have the rear diff leak (pinion/seal fix) that has been recommended by LR to fix.
i'm only guessing that at the time you looked at the settings the diff was locked because of the type of driving you were doing...
I'm going to be skeptical it will still be (if it is) set to "unlock" bc I had switched it to unlock haha.
Have the 4x4 screen showing while driving to see what it does. The diff is pre-loaded slightly prior to take-off in case of wheel-spin but its for such a short time and only slightly loaded that usually the diff symbol stays green. I'm wondering if the setting increases the initial pre-load for when the driver anticipates hard initial acceleration, which would explain the red symbol whilst stationary.
| Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8135
Looking at the pic earlier in the thread, I think looks like there are 3 stages of ‘lock’ indicated by the segments around the lock symbol.
If you watch the percentage engaged figure using a diagnostic tool you will see the whole range yet the symbol only changes to red if the percentage is above a particular threshold and for a minimum time. I can feel the e-diff on my L322 working in muddy conditions yet it takes a lot for the symbol to change from green to red and only flashes on and off for a few seconds unless I keep the boot in. The centre diff tends to stay on for longer but goes off if the steering is turned much. |
