Home > In Car Electronics (L405) > TV sound out of sync L405
Heyloft
2019 Range Rover Vogue SE SDV8 Carpathian Grey
Anyone with a TV in a L405 that experiences sound out of sync with picture ?
Driving me nuts ! Wot's that in old money
Post #542960 4th Feb 2020 10:43am
Felstmiester
England 2015 Range Rover Vogue TDV6 Santorini Black
Have you had a software update? This should sort the problem your having
Post #543156 5th Feb 2020 10:04pm
charlie croker mk2
Freeview / dtv can very easily get out of sync with any TV or set top box and a re boot from no power usually sorts it out . However disconnecting the battery gets messy with the trackers etc . Just change the country in the setup menu of the TV to another out of EU country , then switch the radio on & off and then set it back to the UK and allow it to re tune . Hope this helps .
Post #543164 5th Feb 2020 11:21pm
Heyloft
Thank you for the tips.
I will check the s/w level and follow your tip Charlie C
Will report back
Thanks Wot's that in old money
Post #543167 6th Feb 2020 12:14am
Heyloft
Software up to date and nowhere to change the country in setup 🤷🏼‍♂️
Don’t really want to disconnect the battery Wot's that in old money
Post #543270 6th Feb 2020 9:53pm
charlie croker mk2
Settings / Change / select other country / switch off then on / Revert to UK and allow it to retune .
Post #543281 6th Feb 2020 10:38pm
Heyloft
Different GUI in the L405 2019
Thanks Charlie Wot's that in old money
Post #543290 7th Feb 2020 12:25am
charlie croker mk2
I was wondering about the age of your car , but there must be a way to change it ? suppose you drove to any Mainland EU country its unlikely to be able to change on its own -- or can it ?
PS edit your profile as it still says 2012 car .
Post #543291 7th Feb 2020 12:35am
Heyloft
I agree Charlie, but nothing in manual or on Topix.
Oooos will sort profile Wot's that in old money
Post #543299 7th Feb 2020 8:16am
charlie croker mk2
Any fix for this ?
Post #543846 13th Feb 2020 10:42pm
Heyloft
I’ll let you know after a visit to the dealer on Wednesday 💁🏼‍♂️ Wot's that in old money
Post #543848 13th Feb 2020 10:46pm
Heyloft
Well they said they updated the firmware on the infotainment module.
Not convinced it’s fixed it though. Close, but not quite. Wot's that in old money
Post #545372 27th Feb 2020 7:55pm
charlie croker mk2
Hmmm it might just be how it is , out of sync sound to picture is surprisingly common on TV & recorders .
Post #545380 27th Feb 2020 8:48pm
Site Copyright © 2006-2020 Futuranet Ltd & Martin Lewis
