Home > Technical (L322) > Restricted Performance
Page 1 of 3 123>
jc132jc
Hi guys, I need you help, if possible, I have had the yellow DPF light come whilst driving so straight away tried to get above 50 mph to get it to regen, no joy as I was on a country road, so yellow quickly turned to red.
Limped home and plugged in iid tool and with no surprise very high soot reading and fault code to match, no other new or stored faults codes appeared. So manage to get the DPF cleaned and reset faults.
When out for a spin gave it some wellie and the following happened -
Restricted Performance With the following fault codes -
P1247 Turbocharger boost pressure low
P244B DPF differential pressure too high Bank 1
So for the first code I will check the turbo actuator to see if it’s stuck or jammed, but Iam stumped as to what to check for the second code.
I have also has a low pressure smoke test done to check for any leaks on the intake side but nothing was apparent.
Any help would be much appreciated. Thumbs Up
Post #543968 15th Feb 2020 11:40am
jc132jc
Sorry forgot to add it’s a 2012 V8 Westminster
Post #543969 15th Feb 2020 11:41am
GGDR
It’s nearly always a boost leak, even though you’ve had a smoke test, you really need a good eyeball + white tissue check around every hose and union starting with the four donut hoses. You’re looking for soot escaping which the tissue will show. If you can get a high pressure smoke test it may show up but the low pressure just can’t pressurise the system enough. Search ‘donut hoses’ + ‘restricted’ - common issue but thankfully (hopefully) usually a simple fix. On mine for example a circlip gave up. Bent the clip, cleared the code and sorted.
. Cheers, Greg
Post #543972 15th Feb 2020 12:56pm
jc132jc
Thanks GGRD, would a boost leak cause high soot levels in the DPF ?
I do have a little oil leaking from the plastic intake section connectiing to the butterfly valve, when we smoke tested it we did wiggle it around, a lot, but no smoke escaped, also I have found a little oily dirt on the bottom of one of the donuts.
Post #543976 15th Feb 2020 2:41pm
GGDR
Yes definitely. These intake leaks will create too much soot and fill your DPF
Mine is here: https://www.fullfatrr.com/forum/topic52807.html
Do you mean the throttle body? Mine was the joint between the throttle body and the pipe form the intercooler. Was leaking die to the circlip coming loose.
. Cheers, Greg
Post #543978 15th Feb 2020 3:12pm
Baltic Blue
Number one fault in my 4.4 tdV8 fault log.
You definitely need to fix any air leaks on the intake.
Changing the 4 short hoses is your first job.
Post #543980 15th Feb 2020 3:25pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
When you got home, how did you clean the dpf? BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #544024 15th Feb 2020 9:19pm
jc132jc
AJGalaxy2012, I got a local DPF specialist to come and do it.
Post #544025 15th Feb 2020 9:23pm
DrRob
As above, get a high pressure leak test done.
Do you have the original 4 thin Censored intake hoses on the doughnut?
The updated ones look like this with big jubilee clips.
 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
New Defender D300 90
Post #544027 15th Feb 2020 9:34pm
jc132jc
Dr Rob, I do indeed still have the original rubbish donuts on there so I will change them all while it’s off the road.
GGDR, how did you clear your red DPF warning, as just going for the test drive after having the DPF cleared, my soot levels are very high again. Shocked
Post #544030 15th Feb 2020 9:41pm
GGDR
There are a lot of snake oil DPF fixers out there, in my opinion and experience you need the DPF off the car and in a machine like a "flash" machine.
That's how they do commercial DPFs, London busses for example.
But for now I would focus on finding the boost leak.
The DPF may be ok and if you get into a cycle of normal use should settle down.
. Cheers, Greg
Post #544029 15th Feb 2020 9:41pm
AJGalaxy2012
Ah OK, it seems that the sensors are reporting a high pressure differential which means either a) one or both sensors are faulty or b) the DPF is again blocked. BMW i3 Electric Car
Post #544031 15th Feb 2020 9:41pm
GGDR
What's it reading?
. Cheers, Greg
Post #544032 15th Feb 2020 9:42pm
GGDR
Head over to:
https://www.fullfatrr.com/forum/topic48068.html?highlight=dpf
Pop the kettle on, it's quite a long read if you go through all the cha after the main first section.
. Cheers, Greg
Post #544033 15th Feb 2020 9:44pm
jc132jc
GGDR, I will have to check but I have the yellow DPF warning came on again Censored
Post #544035 15th Feb 2020 9:46pm
Page 1 of 3 123>
