Home > Maintenance & Mods (L322) > SAT Nav
Brian Considine
Simon_CSK wrote:
Brain
So this takes the standard 2004 head unit and allows a reversing camera to be incorporated?
Yes, that's how mines been done.
Not brilliant quality picture but does the job - you only need to see if ther is anything there when reversing. 2003 Range Rover Vogue TD6
Post #544266 18th Feb 2020 1:21am
Simon_CSK
United Kingdom 2008 Range Rover Vogue TDV8 Adriatic Blue
Brian Considine wrote:
Simon_CSK wrote:
Do you havemore info on this?
Relay 1 to provide a switched negative to pin 17 on the blue plug on the TV module.
Relay 2 to provide a switched positive to the camera.
Both relay coils connected to the reversing lights.
Co-ax from the camera centre core to pin 13 on the white plug on the TV module.
Brian
Had a look in the boot and I don't have the relevant blue or white plug. Current cars
Range Rover Sport HSE TDV8
Range Rover TDV8 Vogue
Range Rover P38 Vogue
Range Rover CSK
Discovery 3 HSE
Post #544722 21st Feb 2020 6:17pm
mjdronfield
The plugs go into the TV module. You do have that do you? TV as an option on your menu?
Previous cars :
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #544724 21st Feb 2020 6:23pm
Simon_CSK
Don't have the option on my screen or the cables in the boot. There is space in the boot for the TV receiver Current cars
Range Rover CSK
Discovery 3 HSE
Post #544726 21st Feb 2020 6:43pm
