![]() | Home > Technical (L322) > How to determine where coolant leak is coming from |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1043 ![]() ![]() |
Yes.....tell us which model and engine you have for starters |
Blitz Member Since: 18 May 2019 Location: Billys Creek Posts: 33 ![]() ![]() ![]() |
She's a 2008 TDV8 diesel Vogue SE. |
dazza1983 Member Since: 19 Feb 2019 Location: southampton, hampshire Posts: 529 ![]() ![]() ![]() |
best way is to buy some coolant dye.. And a ultra violet light
What dazza said |
Thanks, but is there a way I can find out without the dye and ultra violet light (to which I have no idea how to use anyway). Is there a bush mechanic's way of determining the leak? |
Due is the quickest and easiest way buddy.
Thanks Dazza. I don't have access to dye, other than food colouring. I'm a couple of hours from an auto shop. I put some baby powder all around the engine, in the hope it would highlight any leaks. Filled up the water, then ran for 10 minutes. There was no issue whatsoever. No leaks, no water coming out under the car - nothing. The temp gauge stayed on normal. The engine warning light was on but no messages regarding overheating. I revved her up to about 4000, still nothing. I noticed the radiator hoses didn't feel like there was any water in them - it was easy to squeeze them. (Don't know if that's normal). When I switcher her off, the water was cold in the expansion tank and the hoses were cold. I'm totally lost. ![]() |
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 612 ![]() ![]() ![]() |
Hi Blitz
Thanks Bigbo.
Hi Blitz
Thanks for your help Bigbo. I'm waiting for it to cool down, then I'll have a go at getting the cover off and see what happens.
I think your first job is to get the engine cover off so you have visibility. Unfortunately overheating issues need you to work on a hot engine, just be careful.
Thanks David. I just managed to get the cover off. I can't see anything amiss. Wow, it's like looking at an alien compared to the old Series III! I have no idea with all the pipes going everywhere!
He He, now you know why they put a cover on! lol
