![]() | Home > Technical (L322) > Restricted Performance Red Light |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3232 ![]() ![]() ![]() |
No such thing as a stupid question in my book. We all learn through asking questions. I knew nothing about these cars when I got my first one 10 years ago. Now I can help a little bit thanks to the voluminous knowledge of the members here.
jackie-o Member Since: 15 Jun 2018 Location: Sweden Posts: 226 ![]() ![]() |
Dolphinboy, not sure if it was high preassure but they did a smoke test, thats how they found the air leak from the back of the engine. They suspected something with EGR but they need to remove the inlet manifold to have a closer look.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4340 ![]() ![]() ![]() |
Double check it has the 4 updated, tougher intake hoses. Two either side of the doughnut. Look in my gallery to see them. Flimsy originals can split and leak. Easy job. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Thanks Rob, I will probably take it to an indy to have it checked as LR here in Sweden charge ridiculous prices...
@jackie
@Dolphinboy, I live in Sweden since 6 months back but I still work in Amsterdam so car is a little but back and forth. At the moment it´s in Sweden.
Any good mechanic should be able but anyone with experience of Landrovers would be best. I would advise using genuine parts (unless someone can argue otherwise?). |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 910 ![]() ![]() ![]() |
Yes Jackie, that's the correct thread for the O ring replacement which goes on to describe the oil cooler gasket replacements too.
Right, just had my car back from the LR dealer having had a red dpf light come on and not able to clear - had rear sensor replaced. They couldn’t force regen the dpf (they got lower soot readings but the engine Ecu failed to recognise the lower reading and it remained in restricted power with red light on.)
So....have been driving the car for a couple of weeks now in waiting for an indy specialist to take it on March 2nd.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2687 ![]() ![]() |
Try starting then stopping the engine several times. Some faults persist until a specific number of error-free starts have occurred. |
GraemeS, the thing is that it started up again without any warning lights, also didnt come on while driving.
hhmmmm. The second turbo comes "on" when the revs get to 2500 or above. your power loss at around 2000 rpm could be something to do with your pipework for the turbos having a fault? |
@dolphinboy, the secondary turbo was my thought as well as the car has been running fine for two weeks when I keep it below 2.000 rpm...
