![]() | Home > Technical (L322) > Restricted Performance Red Light |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4348 ![]() ![]() ![]() |
I had a loose vacuum pipe on secondary turbo after it was fitted. Took them seconds to diagnose it and now all fine. Simple human error but all fixed quickly |
Keep us posted |
jackie-o Member Since: 15 Jun 2018 Location: Sweden Posts: 226 ![]() ![]() |
Codes back;
following some own detective work I found this bulletin from 2013; LTB00504V3
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3267 ![]() ![]() ![]() |
check out these links. Its a common topic on Disco and Jag forum.
So, first update from the garage and no real news...
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2751 ![]() ![]() |
I'm surprised that the garage wasn't able to spot the source of the escaping smoke by removing the cabin air intake which is only held in place by 2 nuts which are easily removed. With the air intake removed visual access to the back of the engine is enormously improved.
Graeme, yeah I´m also a little surprised it has taken a full day and still not found the leak....
There is a great thread on here on changing out the oil cooler gaskets. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Thanks Rob, just found it in the Wiki.
The inlet manifolds are the plastic covers that sit on top of each head. The one in the centre is the intake manifold which is easily removed and which can also split, hopefully only in the original design as it too has been revised. Hopefully your leak is from one of the 4 short hoses that connect the intake to the manifolds as the design of those hoses has also been revised to simple, straight hoses. |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 700 ![]() ![]() ![]() |
It's only a thought......but if the garage is going to take 4hrs to change the oil cooler O rings, would it be sensible to change the whole oil cooler 'just to make sure'? If it was a five minute job to do the seals, fair enough, but if the oil cooler goes 't*ts up' in a while, you've another 4 hrs labour to go back to square one?
@GraemeS; they are fairly certain that the leak is not coming from the manifold but further back in the engine.
jackie-o: I'm pretty new to this lark, but, I believe there's an O ring that sits at the back of the engine high up that is a common oil leak problem. If it's that particular one that's leaking then apparently it's pretty easy & cheap to replace.
