Home > Maintenance & Mods (L322) > 05 L322 REAR SUSPENSION GOING DOWN
deltic
Ireland 2005 Range Rover SE Td6 Bonatti Grey
Hi all , the rear of my 05 l322 keeps deflating both sides when left parked up for 2 or 3 days no lights on the dash when i start it up it all
goes back to normal and is grand all day it seems to go down very slowly like you never notice it till its down i had a problem with the cruise control not working all the time and the radio controls frozen but they came back working any ideas thanks.
Post #545059 24th Feb 2020 7:49pm
horse86
United States 2014 Range Rover Autobiography 5.0 SC V8 Causeway Grey
you've got a leak somewhere. If its worse when its the coldest days that's a clear sign of a leak most likely in the air bag. Can be tricky trying to find the leak. When the air bag blows you'll know b/c it will throw a suspension fault and put you on bump stops 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #545072 24th Feb 2020 9:31pm
deltic
No faults shown dont think its the bags had a good luck
Post #546707 10th Mar 2020 7:05pm
deltic
Post #546708 10th Mar 2020 7:06pm
mjdronfield
As above, you won’t get a fault till it blows.....then it’s, well, obvious, so no fault message really needed.
I think people tend to live with it, or you can spray soapy water on the bags etc and look for bubbles.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #546709 10th Mar 2020 7:13pm
Always
Sounds like a leak to me. Just because you can't see it doesn't mean it isn't there.
I'd be putting the car in off road mode and spaying the bags with soapy water / plumbers leak detection spray and having a real good look at them - both.
If it is a leak, you're not getting any warning lights because the car doesn't (yet) know that anything is wrong. What'd worry me is that your air compressor will be working a lot harder than it needs to in order to keep the bags inflated. It could end up being a bigger bill than you'd want.
You still on the original bags? I'd say 15 years is a good run.
Just replaced my fronts after 13 years. One had a leak, the other was fine - but no sense in doing only one. No warnings at all relating to the inflation (or not). A couple of error messages caused by the blocked compressor exhaust fitting - but that's a totally different issue.
Post #546715 10th Mar 2020 8:09pm
deltic
Cheers for that did spray l
soapy water on them no luck
Post #546947 12th Mar 2020 9:03pm
horse86
Look for leaks at the junction boxes too where the lines hook up. 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #546967 13th Mar 2020 4:45am
Always
99% certain you've got a leak somewhere. If you had a tyre that was slowly going flat over a few days what would you conclude? Same logic. How often can you 'see' a slow puncture?
If you want to eliminate 'electronic trickery', just park it up and disconnect the battery, then leave it for a few days. If it still sinks you've got a leak. If it doesn't, I'm wrong.
Post #546974 13th Mar 2020 9:51am
