Home > Maintenance & Mods (L322) > Brake pedal travel
dennij
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
Brake pedal travel
Evening all
Nice easy question this one. How far does your brake pedal travel before you feel the brakes begin to apply?
My 2011 TDV8 4.4 seems to want to travel about half way before the brakes feel like they are beginning to apply. That’s far further than any other car I drive and doesn’t exactly inspire confidence.
Now it is going into my independent garage on Thursday as I suspect the rears are not fully applying and it would be nice to have some input from other FFRR drivers as to what you find when you press your pedal. Hopefully better than mine
Post #544934 23rd Feb 2020 8:01pm
Gazcw
United Kingdom 2011 Range Rover Vogue TDV8 Baltic Blue
Mine is about the same. I replaced a seized caliper today and bled the brakes. Took it for a drive and the pedal is about halfway before it starts to brake. 2011 4.4tdv8 Vogue
Baltic Blue
Post #544935 23rd Feb 2020 8:16pm
dennij
Hi Gaz, thanks for taking the time to respond I was hoping with over 80 views to get a better response but there you go. I will let you know what I find out later this week once the garage has finished with it
Post #545134 25th Feb 2020 6:07pm
Gazcw
Thumbs Up 2011 4.4tdv8 Vogue
Baltic Blue
Post #545139 25th Feb 2020 6:34pm
DrRob
Mine has a bit of travel before it bites Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #545145 25th Feb 2020 7:42pm
Swipe
United Kingdom 2004 Range Rover Autobiography Td6 Java Black
My Td6 has the same amount of brake travel before it bites, have replaced both rear calipers as they were sticking.
Was hoping it might improve the brake feel once the callipers had bedded in the pads, but not noticed any real change.
Suppose it’s the way it’s meant to be. 2004 Autobiography TD6 Java Black
Post #545162 25th Feb 2020 9:16pm
dennij
Gentlemen, many thanks for taking the time to respond. Sounds like the pedal travel is normal from what I'm reading. I'll post back here what the garage say after they have looked at it tomorrow, although I suspect it's going to be one of those "couldn't find a fault, and here is your invoice" conversations.
Post #545199 26th Feb 2020 11:54am
jordon0
United Kingdom 2010 Range Rover Vogue SE TDV8 Zermatt Silver
just checked mine and you can feel brakes starting too apply after about a inch of travel
half way is a full on emergency stop
mine is also 4.4tdv8 with 6 pot calipers
Post #545220 26th Feb 2020 4:07pm
dennij
Hi Jordon, that's about what I would expect to be honest, in my case it's almost half way before you feel the brakes apply. My Freelander 2 on the otherhand has exceptional brakes, so much so that I headbutted the sun visor when I jumped in it to move it out of the drive the other day. I had become used to having to press the FFRR pedal so far before I had any brakes applying.
Post #545221 26th Feb 2020 4:12pm
Jri711
United Kingdom 2010 Range Rover Vogue 4.4 V8 Santorini Black
Mine (4.4 tdv8) travels about half way befor starting to bite ,which is about the same as the two previous ones, 4.4 petrol & 3.6 tdv8 being a ‘ off road ‘ vehicle , would you want breaks that would just lockup at the slightest sign of anything remotely slippy? I know I wouldn’t
Post #545238 26th Feb 2020 6:58pm
Gazcw
Off road?? I thought they were for seeing over the hedges. Doh! 2011 4.4tdv8 Vogue
Baltic Blue
Post #545244 26th Feb 2020 7:49pm
dennij
Collected car from the garage this afternoon Turned out there was trapped air in the system that the computer bleeding process couldn’t shift so they went back to the old fashioned method and after a litre of brake fluid being pushed through the system all the air was removed. Brakes are 100% better, when I press the pedal now the brakes begin to bite after around an inch of travel, I’m now able to brake progressively.
Post #545355 27th Feb 2020 4:12pm
jordon0
glad you got it sorted
but by the amount of replies that consider half pedal travel as normal i would say
there are some poorly maintained motors about
Post #545374 27th Feb 2020 8:16pm
dennij
Yes it does make you wonder, the responses didn’t really confirm how the pedal should feel as there seemed to be a mixture of answers. Now having mine fixed I can say that it feels as I would expect any cars brakes to feel especially modern ones with ABS etc. Perhaps a lot of people don’t bother having the brake fluid changed as part of the service schedule causing it to become less effective.
Post #545414 28th Feb 2020 10:10am
Bl4ckD0g
Netherlands 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
I agree I was almost thinking mine was abnormal with little travel 😂
There is honestly no material difference to any other car
Post #545420 28th Feb 2020 11:17am
