![]() | Home > General > 3.6 or 4.4 TDV8 |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
Good decision, you wont regret it. Just make sure the turbo drain mods have been done. BMW i3 Electric Car
RRDunc Member Since: 26 Feb 2020 Location: Leicestershire/Warwickshire border Posts: 520 ![]() ![]() ![]() |
OK. Thanks for the advice. What mod needs doing and is it visible and thus easy to check?
Do a gentle drive for 10 miles or so and then kickdown, watch in the mirror, if it resembles a scene from a bond movie with loads of smoke the mod needs to be done.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4347 ![]() ![]() ![]() |
They don’t all suffer from this. Might doesn’t. If it does smoke like AJ says then it needs doing. Some garages won’t do it as it involves drilling into sump. Swarf! Even Rovertune won’t do it. Lots of info on here on who will do it though |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7995 ![]() ![]() ![]() |
Mines not got it and I have no issues. It was never done at factory at that time, that came near the start of L405.
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 700 ![]() ![]() ![]() |
Re-drain mod: I tend to drive mine like Miss Daisy & I was petrified that mine hadn't been done & needed doing. Turns out mine hasn't been done so I flawed the old girl on a slip road to 3k rpm & still no smoke, so don't get too paranoid about it.
Its not a case of driving like Miss Daisy, driving sensibly around a local area seldom will you need to exceed 2500 rpm and thereby allowing the oil to build up if so affected. The oil dumping into the engine doesn't do the DPF any good as the oil smoke passes through and the soot level does increase dramatically. Back pressure on the oil return line isn't a good thing either, flow of oil is what you need through a turbo to prolong it's life. Having to drive it on a regular basis over 2500rpm isn't a solution either.
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 782 ![]() ![]() |
I agree with the majority on here that the 4.4 is a much better car in many many ways BUT I wouldn't rule out a 3.6 completely.
Well....I'm still leaning towards the 4.4 but there's time to change my mind yet!
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35834 ![]() ![]() |
that button releases the upper and lower glove boxs.. ... - .- -.
Thanks, Stan. It'd been driving me nuts for a couple of days!
Simmoto Member Since: 17 Jan 2020 Location: Scotland Posts: 48 ![]() ![]() ![]() |
Interesting Cass to hear a real world opinion from an owner with both. |
SS.Lyria Member Since: 01 Dec 2016 Location: London Posts: 269 ![]() ![]() ![]() |
What about a 5.0 Petrol V8 |
paulparry82 Member Since: 04 Mar 2020 Location: Merseyside Posts: 21 ![]() ![]() ![]() |
I went for the 4.4 on a 2011 model and it still drives like new. No major issues in 18 months of ownership either. I wasn't disappointed |
