Home > Technical (L405) > Ticking noise during engine start
smakil
United Kingdom 2014 Range Rover Vogue TDV6 Fuji White
Hi.. Only had the car for just over 3 months. I haven't noticed the ticking noise until recently and it doesn't last more then 5 seconds upon starting the engine. Any advice would be great. This is my first Rover and I love her to death, would hate to see her fail on me Big Cry . Current
RR Vogue MY14 3.0 tdv6
Audi S3
Previous
F82 M4
F32 420d
Golf TDI 1.6
Post #546174 6th Mar 2020 11:11am
ABAB
United Kingdom 2016 Range Rover Autobiography SDV8 Loire Blue
Have you got heads up display by any chance? Mine ticks for a bit on startup and it took me ages to work out that it was this. 2016 SDV8 AB
Post #546201 6th Mar 2020 3:30pm
smakil
Nop.. I do not have heads up on mine, i tried to follow where the noise is coming from and it's from underneath and like i mentioned its only upon starting up and i'd say it ticks no more than 4-5 seconds Current
Audi S3
Previous
F82 M4
F32 420d
Golf TDI 1.6
Post #546218 6th Mar 2020 4:34pm
Weegie
FBH starting up? John
GAP iiD BT-Sold
Post #546219 6th Mar 2020 4:46pm
knwatkins
Sorry to resurrect an old post, but I just came across this and noticed there was no conclusion.
The 3.0 S/TDV6 has a small chain in each head to between the exhaust and inlet camshafts. When the oil pump becomes a little worn and the clearances get a little too large, the oil in the heads drain down back to the sump when the engine is switched off.
The rattle noise you hear upon initial start up is due to the two chains in the heads not having enough lubrication for the first few seconds. As soon as the oil pump has generated the oil pressure and pumped the engine oil up to the heads, the noise disappears as the chains and guides now have enough lubrication.
Always give the 3.0 a bit of time (say, 30 seconds) between start up and driving. This allows the oil pressure to get up and make sure everything is lubricated adequately before applying load to the engine. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #569603 12th Oct 2020 11:05am
