![]() | Home > In Car Electronics (L322) > Fuel gauge giving wrong reading |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
Hahaha, I had a similar problem when I picked mine up last week. At the dealer, it had about a quarter tank. I filled it up and it went to full. It went down normally for about 150 miles, then the fuel gauge was slowly going up |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
The fuel gauge takes an average reading across two level senders, as the L322 has saddle tanks...
neil3728 Member Since: 24 Feb 2020 Location: Howden Posts: 58 ![]() ![]() ![]() |
Thanks I had read about the senders giving bad reading if there was a problem with them but all cases I could find was only about low reading, If it can give all different readings I'll take a look at replacing the unit. No doubt its not going to be an easy job. 2013 Vogue 4.4 TDV8
Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1099 ![]() ![]() ![]() |
http://www.fullfatrr.com/gallery/albums/us...6294~1.pdf Current: 2011 FFRR Vogue SE 4.4 TDV8
Thanks, now I just need how to remove the sender from the tank. 2013 Vogue 4.4 TDV8
There are 2 units in the tank, you'll probably be best to remove both (they are connected together) and work on replacing the connectors with them out of the tank -- it's a squeeze to get them out through the hole, but with a bit of Houdini they will come out. Just be careful with the plastic parts on the top of the springs -- mine was brittle and I broke it when removing |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 752 ![]() ![]() |
I've just completed this job on my 2010 3.6 TDV8 as my fuel gauge stopped reading completely.
Thanks for the advice,
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 774 ![]() ![]() |
Just be aware that if the guage reads empty then your car will go into limp home and possibly stop altogether (I can’t remember exactly what mine did), even if you have a full tank |
Just be aware that if the guage reads empty for long enough, then your car will go into limp home and possibly stop altogether (I can’t remember exactly what mine did), even if you have a full tank |
Reportedly it stops -- didn't happen to me, but that's what others have stated Current: 2011 FFRR Vogue SE 4.4 TDV8
I think mine did stop at some point but I can’t be certain however it definitely went into limp home repeatedly- it was a 120 mile trip home that I’ll never forget! |
