![]() | Home > Maintenance & Mods (L322) > L322 air suspension replacement questions... |
| Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3276
The price quoted - £276 incl VAT - is a good price. Interestingly Island 4x4 used to have them labelled as Delphi. I would be happy to use them myself. I did replace the fronts on my Td6 when I had it with the Island products for the earlier L322.
| lighthouse Member Since: 22 Feb 2016 Location: Great Notley Posts: 513
On my previous L322 I did the front and left the backs and had no issues. |
| dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291
getting the strut bolts out can be a bitch as they tend to sieze
| paulbrown22 Member Since: 23 Dec 2017 Location: London/Poole Posts: 358
1.) Yes, Delphi seems to be part of the BWI Group, who are the original suppliers to LR. The original ones on my car were branded BWI. The team at Island 4x4 are super helpful if you call, or email them with your VIN, and they will give you all the options applicable to your specific vehicle.
| Always Member Since: 04 Nov 2013 Location: Yorkshire Posts: 58
Superb info; thank you gents. Just the fronts it is then!
| AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464
Soak the bolts from all angles with Plusgas penetrating fluid for a couple of days prior to doing the job. Mine came out really easy by doing this. BMW i3 Electric Car
| Springer Member Since: 15 Nov 2017 Location: Merseyside Posts: 104
Did my fronts last year with Delphi ones from 4x4 Island not too bad of a job just remember to torque the bolts up with the weight of the car on the wheels |
Torque settings - does anyone know where I can find this info for the main bolts in particular?
They are listed in the Workshop Manual (available in the wiki here), or on at least one of the YouTube videos I watched before doing this job.
Thank you all for the input. Job completed successfully.
WD40 is useless as a penetrating fluid, in fact it's useless except for cleaning and water displacement. Plusgas or diesel / paraffin make much better penetrating fluid. It's a shame that Land Rover dont lubricate these things on assembly, it would save a lot of heartache. BMW i3 Electric Car
You must never lubricate nuts or bolts! If a nut or bolt is lubricated in any way this has the effect of doubling the tensile load that can be applied. This results in the potential applied load for a bolt being doubled at the same tightening torque. |
I hear that sort of thing all the time, now consider rusty nuts rubbing on a corroded metal fitting which would present much more friction, the torque measurements have gone out of the window. During assembly the stem of the bolt could easily have grease or other corrosion preventative / protection applied leaving the threads clean and therefore complying with the torque measurement recommendations.
| All times are GMT |
