Home > Maintenance & Mods (L322) > Tow Bar Query
lighthouse
United Kingdom 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
Have you got a blow torch? also spray loads of wd40 on it for the next couple of days so it can work into the gaps and hopefully loosen it up.
Post #546064 5th Mar 2020 10:29am
neil3728
United Kingdom 2013 Range Rover Vogue SDV8 Baltic Blue
Small blow torch yes, Not sure how much heat it will give out, but its the best ive got so I'll give it a go.
Plenty of WD40 between now and Saturday 2013 Vogue 4.4 TDV8
2014 Defender 110. now sold
2018 Range Rover Sport.
Post #546065 5th Mar 2020 10:30am
lighthouse
I have a similar challenge, brought the RR last week and this is the towbar I was handed.
Post #546066 5th Mar 2020 11:02am
neil3728
Looks as good as mine, Laughing 2013 Vogue 4.4 TDV8
Post #546067 5th Mar 2020 11:10am
lighthouse
I have no keys for r so have managed to get new neck bit off flebay with keys and hopefully can drill out the old lock and separate these so i can use the attachment then I need to find the correct bolt to hold the thing into the square fitting.
Post #546069 5th Mar 2020 11:34am
Weegie
Plusgas would be better. John
GAP iiD BT-Sold
Post #546071 5th Mar 2020 11:36am
neil3728
There is a good video on U tube about how to take one apart without the keys. no drilling needed just a hammer and a punch, to get the lock mechanism out. 2013 Vogue 4.4 TDV8
Post #546075 5th Mar 2020 11:43am
lighthouse
thanks will do a you tube search.
Post #546078 5th Mar 2020 12:00pm
neil3728
Big hammer won the day. Amazing how easy it came out with the correct tool.
Now to source a new RR spec drop plate.
Did I image it or was someone after the old dust cover from the top of the detachable part. 2013 Vogue 4.4 TDV8
Post #546307 7th Mar 2020 3:19pm
